第109頁,共111頁 第一第一 ... 95999107108109110111 最後最後
顯示結果從 1,081 到 1,090 共計 1107 條
  1. #1081
    http://www.avsforum.com/avs-vb/showthread.php?t=1103498
    這邊有一些Theta的news:)
    引用 作者: BOULDER2060 查看文章
    THETA是独立参展的吗?现在的THETA没看到什么新东西了哦。
  2. #1082
    沒有,主要是因為這展房其非主角:|
    有没有架子左上面,皇帝功放其他的资料啊
  3. #1083
    想不到這裡就有好康的,可是要破100才行
  4. #1084
    引用 作者: sp007 查看文章
    還有抽中耶,.....
    我也有喔...
    開工了,趕緊來匯給小葉大..
  5. #1085
    引用 作者: john925 查看文章
    我也有喔...
    開工了,趕緊來匯給小葉大..
    恭喜哦...........
  6. #1086
    引用 作者: john925 查看文章
    終於出了有數位輸入的播放機了...
    http://fr.cinenow.com/videos/2023-es...-produits-2009
  7. #1087
    哇!好猛的排插,貫穿保險桿...
    :O
  8. #1088
    引用 作者: john925 查看文章
    我只是好奇Esoteric出數位輸入的player要怎麼和現有的D-03, D-05做出市場區隔
    Esoteric將推出D-03, D-05 upgrade solution, 價格約$1,200USD
    Owners of the music class high-end were able to transfer audio recordings stored on your
     hard drive in its tsifroanalogovy converter ESOTERIC (D-03 / D-05) through a USB-interface
     and wireless connection.
      The company has released a kit to upgrade: USB-transmitter and an entrance fee to listen to
     high-end audio system, not only compressed music files that are broadcast as streaming audio,
     and CD quality music, recorded on the hard drive.
      All that is stored on the PC HDD drive - thousands of MP3-files, uncompressed audio to
     FLAC, AIFF or WAV, the transfer of Internet radio or compressed lossless copies of
     CD discs - all you can listen to the uncompromising quality audiofilskoy high-end system.
      Suffice votknut miniature transmitter in the USB-port PC, (or to pave the USB 2.0 cable
     between the PC and the DAC) and can play music on a computer using i-Tunes,
     Windows Media Player, Media Monkey, etc.and it poletsya through your audio system.
      The system transmits the flow of PCM signals, decoded in the pre-PC, at a frequency of 2.4
     GHz and up to 30 meters, with options to 16-bit / 48 kHz.
      Established in D-03/D-05 input card USB decodes the signal and reduces dzhitter before
     sending in the DAC, Thus, it is possible to achieve high-quality digital transmission and
     processing of signals.
      Requirements for the PC:
       - PC or Mac with a USB port (USB1.1 or higher)
       - OS Windows XP, Windows Vista, Mac OS9.1, Mac OS10.4.3
       - Software for playing music using the i-Tunes, Windows Media Player, Media Monkey, etc.
       - Music files in any format, compressed and uncompressed: WAV, MP3, FLAC, AIFF, etc.
  9. #1089
    引用 作者: musk 查看文章
    很有興趣的東西...只是還買不起...(sweat)
  10. #1090
    引用 作者: john925 查看文章
    類似的產品廣州度高的價格比較便宜,也可以滿足一般的需求。
    廠家產品介紹http://www.dugood.com/WDDC-1.htm
