第36頁,共43頁 第一第一 ... 263435363738 ... 最後最後
顯示結果從 351 到 360 共計 463 條
混合查看
    引用 作者: chrono3579 查看文章
    感謝SAM兄持續更新
    之前手邊沒有intel CPU尚未嘗試使用,而昨天入手了intel 12400與相關零組件後,今天也馬上嘗試安裝看看
    在安裝kernel 與MPD會提示錯誤如圖
    看起來是憑證錯誤無法驗證域名導致的?
    應該是DNS無法解析網域名,config -> network, DNS改為ISP提供的試試。
    謝謝SAM大的解答,確實是網路設定問題!
    使用MPD,一開聲真的是驚呆了...聲音清澈,殘響在聆聽空間中迴盪,美的難以言喻
    這是個人至今聽過最好聲的播放系統~
    不知為何我的paypal付款失敗,稍晚再試試
    這是個人至今聽過最好聲的播放系統~
    台灣內,PayPal 不能直接付,法規限制,所以不用試了。
    若要Donate,可以私訊喔,小弟再提供資訊。
    https://www.pc.gov.au/__data/assets/...air.pdf#page=6
    https://www.cbc.ca/news/thenational/...airs-1.4859099
    When presented with the computer the Apple Store in Toronto said would cost more than $1,200 to fix, Rossmann identified a pin that should have been connected to the laptop's back-light that was not making contact.
    After adjusting the pin, the issue appeared to be resolved – something Rossmann said should not equate to a cost of $1,200.
    "If somebody wanted me to just bend the pin back, I wouldn't charge them for that," he said, adding that he would ask his customers for between $75 to $150 if they wanted to replace the pin entirely.
    "Ninety-nine per cent of the time, just bending the pin back, it'll allow it to last until the end of the life of the computer."
    When asked to respond to the incident and to widespread allegations of similar corporate behaviour, the company declined to provide a spokesperson. But it issued a statement claiming their customers are best served by Apple's "certified experts using genuine parts," and denied systematically over-estimating repair costs.
    修理入水MacBook索價1200加元蘋果被指誇大費用
    https://hk.on.cc/hk/bkn/cnt/amenews/...00972_001.html
    代工廠自殺頻傳 Apple將調查
    https://newtalk.tw/news/view/2010-05-26/5551
    BBC揭血汗代工廠 蘋果高層動怒
    https://news.ltn.com.tw/news/world/breakingnews/1186826
    蘋果電子書價格壟斷一案上訴失敗,面臨4.5億美元賠償
    https://www.ithome.com.tw/news/97111
    2017 爆偷降速 iPhone!蘋果花 5 億和解,每人賠款今天曝光
    https://www.inside.com.tw/article/32...rmance-lawsuit
    MacBook Pro螢幕驚見「灰塵門」災情!這些型號一損壞維修價上萬元
    https://tech.udn.com/tech/story/123152/7581079
    中國雙11買氣不旺蘋果銷量慘輸華為、小米一大截
    https://enn.tw/456552/
    蘋果營收連4季下滑 中國消費疲軟雪上加霜
    https://www.digitimes.com.tw/tech/dt...H8NDMSR851FHDL
    蘋果市值蒸發超過 1600 億美元,跌出 3 兆美元俱樂部
    https://www.inside.com.tw/article/32...low-3-Trillion
    幸好 sam0402 兄沒有選擇 Apple Silicon,畢竟還是 Intel/AMD 比較好,反正小弟也不會有任何意欲購買蘋果的產品了。
    基本上(絕)大部分企業也沒有甚麼商業道德可言,無知的顧客就好比送羊入虎口,只是蘋果於這方面實屬「龍頭一哥」罷了,哈哈。
    引用 作者: seeteeyou 查看文章
    ...恕刪
    最後沒在Apple Silicon開發ArchQ 主要原因是:沒法用ISO的方式安裝,這樣就沒法做版本控制。安裝的時間點不同,套件就無法一致化,我就會疲於奔命在版本更新上,而且無法維持聲音的穩定。
    第二是音響最重要的就是電源處理。PC的電源供應處理彈性大,包含了compile時的電源供應品質,加上BIOS的調整也是影響聲音巨大。
    以上這些都是Apple的環境下無法做到的,所以就不處理了。
    CPU 被殺?!
    在Q441 6.1.54出線之前,小弟用的i12500一向表現不錯,剛好夠用,摸到441K的邊邊。6.1.54版上架後,發現掉到425K 左右,但聲音明顯進步太多,對此數值就忽視不管,也沒打算改用Q396。只覺得Kernel 躍升不少,發現有些專輯的錄音不佳,想必是鑑別力提升的結果。
    上週美亞黑五,看到i12600K 價格合理,基頻可上3.7GHz,加上對12500 不能到達到441K仍有些芥蒂,索性下單一顆來試試。
    昨日到貨,因為是低電壓派,就直接調整為3.3GHz來聽。不聽還好,一聽才知小弟又誤會大了,原來不是錄音不行,是12500被殺了。
    12600K 聽起來暫態變好,飽滿(厚)度更高,低頻更結實。原認為錄音不行的全都正常了,有張88.1KHz的專輯本來聽了會頭暈,這下問題全消失。
    原來,Q441是很吃資源的,12-14代系列應該至少要有3.3GHz的基本頻率才餵得飽,這是指用低電壓(<0.8v)的情形下。下午也試過3.6GHz,電壓要升至0.83v才行,但聲音毛邊明顯,這不是小弟要的聲音。
    另外Q441 不只殺CPU,連小弟的電源也是;因為它效能太好,會突顯出系統的問題!
  7. The Following 5 Users Say Thank You to sam0402 For This Useful Post:
  8. #7
    引用 作者: sam0402 查看文章
    CPU 被殺?!
    請問一下Sam兄,方便分享您提到的您電源系統的缺點是?
    從我的iPhone使用Tapatalk 發送
  9. #8
    引用 作者: stchen 查看文章
    本來在McFifo Clean Side 用了兩顆Apple 140W GaN,後來手癢把同軸輸出的供電改用另一顆GaN。在舊Kernel 時覺得動態大了一些,音色也沒變差。沒想到新Kernel就把它殺了,怎麼聽都怪,只好換回Apple的。目前看來,Apple 的沒啥問題,算是安全的電供,可惜無法加電容,要再找到更優的5V GaN可以加電容的應該不容易。
    會去用Type-C 的GaN應該只有小弟我了,所以一開始就沒打算提。
  10. The Following 2 Users Say Thank You to sam0402 For This Useful Post:
  11. #9
    另類版本比較? 會堂的空間呈現
    Kernel_6.1 對於空間的殘響表現力的強大,相信連初入ArchQ的樂友都能感受到。小弟CPU更新為i12600K 3.3GHz後,聲音更明確穩定,空間的殘響同樣的更清昕自然。
    下午聽了一些人聲和合唱的目曲,發現ArchQ能展現另一種聽音樂的樂趣:演奏會堂的呈現
    為何用會堂一詞?因為小弟聽的曲目主要是在教堂裡的音樂,包含合唱、管風琴這類型的。這些場地並不是為音樂演奏設計的,但通常會有管風琴再加上長形的空間,造成有相當長時間的殘響,讓音樂在空間中迴盪不已,就有餘音繞梁數秒的效果;這些是音樂廳不會有的效果。
    以下兩張是凡爾賽宮內的合唱曲,它的空間就像是深不見底的長廊,殘響像在山谷裡一直迴盪至深遠處。
    這兩張在是巴黎聖母院聖誕夜彌撒的錄音,可以明確的聽到管風琴在左側,合唱團在右。合唱聲出聲後的殘響由右至左反彈回來約一秒後與後來的旋律混合,管風琴亦是由左至右。最後兩種聲音變成四種在空間中交錯混合,造成熱鬧的氣氛,非常有教堂的參與感。
    這張是巴黎瑪德蓮教堂,是個相當大的教堂。人聲在前,管風琴在深遠處發聲;人聲的殘響也是傳的很遠,可以聽出空間相當大。
    這是非常有趣的體驗,沒想到多了一種聽音樂的樂趣。
  12. The Following 4 Users Say Thank You to sam0402 For This Useful Post:
  13. #10
    MPD無法播放CD的修正
    小弟一直以為MPD可以正常播放CD,今天發現一個小問題,原來安裝系統時,MPD並未被授權使用光碟機。
    若有這個問題,使用下面指令就可以修正:
    代碼:
    sudo usermod -aG optical mpd
    另外,也要確認一下 /etc/rc.local 裡的 "systemctl stop systemd-udevd" 是在註解(有#)的狀態;也就是systemd-udevd 服務是開啟的,這樣放入CD時,音軌清單才會自動跑出來。
    還有在/etc/mpd.conf 的audio_buffer_size 設定在2048或4096,這樣才不會在讀取CD時音樂被中斷。
    小弟這次和硬碟檔案比較,硬碟的聲音密度略高一些,其他沒太大差異;不同的硬碟聲音也不同,所以有點差異是正常的。
