第3頁,共129頁 第一第一 123451353103 ... 最後最後
顯示結果從 21 到 30 共計 1283 條
  2. #22
    ASR 展出清單
    Digital source : DCS Scarlatti System
    Analog Source : Acoustic Solid
    Argento Audio
    YG Acoustics Anat Reference II Professional
    2X ASR Emitter II Exclusive Battery in Bi- amping
    Analog phono preamp Basis Exclusive
  3. #23
  4. #24
  5. #25
  6. #26
  7. #27
  8. #28
    Nordost
    Odin Digital Leads
    Odin Tonearm Leads
    High-End Show, Munich, Germany MOC, 21st – 24th of May 2009
    As usual, Nordost will be in attendance at the Munich Show, supporting our German distributor Connect Audio (www.connectaudio.de). However, this year our famous demonstrations will be taking a slightly different approach, with separate, timed presentations for the latest cable and Quantum mains distribution products.
    New Products
    Odin Digital Leads
    Rounding out the Odin cable range, Munich will be the first opportunity to see – and hear – the new dedicated digital and tonearm leads. These system critical elements are positioned right at the beginning of the signal chain and consequently, have a disproportionate effect on overall signal quality.
    Just as there should be, there are two different digital leads, with specific topologies to meet the 75 Ohm (RCA/BNC) and 110 Ohm (AES/EBU balanced) standards. The 75 Ohm lead is a true co-axial design, whereas the balanced lead employs three separate, twisted conductors. But both leads share Nordost’s most advanced technology, dual micro mono-filament construction and TSC virtual
  9. #29
    Sooloos adds RackMount models for custom installation
    Sooloos Ensemble
    The Munich High End Show doesn't officially start until tomorrow, but we've already had advance information from Sooloos on its planned product launches at the event.
    The manufacturer of server-based home entertainment systems (now owned by Meridian Audio) is adding new RackMount options to its existing line-up.
    The new RackMount models will be available as dual-rack-space (2U) designs for Sooloos's Source, Twinstore and Ensemble devices.
    While retaining the core features of their standard counterparts, the RM models also include several upgrades, including internal fans for heat dispersion and a front-panel power switch for easier installation.
    "Custom installation remains the core of our business," says Sooloos chief operating officer Peter Wellikoff. "We felt it absolutely necessary to support the installers, not only by providing rack-mountable options, but also to produce these products at no additional cost."
    The Source: One RM and Source:Five RM serve as the hub of a Sooloos system, and provide the audio outputs for connection to a stereo or audio distribution system.
    The Twinstore RM is a network attached storage device featuring two removable hard-disk trays: one for primary storage, one for backup.
    The Ensemble RM combines the functions of the Source and Store components in a single chassis. It has a 1-terabyte removable hard-disk tray for storage, and has analogue and digital outputs to feed up to five discrete zones around the home.
  10. #30
    :)祝旅途愉快。事事順利。8)8)
