第8頁,共129頁 第一第一 ... 6789101858108 ... 最後最後
顯示結果從 71 到 80 共計 1283 條
  1. #71
    mbl在16系列的D/A解碼上,會將USB解碼當做標準配備,今年已於現場發聲,型號有可能會是"F",未來不久出貨的就是內建了
    好像只有到 96kHz ㄋㄟ...
  2. #72
    引用 作者: chkuo2 查看文章
    嚇死倫ㄚ...
    我看這些線材不下 500 萬哩... :O
    現場有沒有批發價可以買ㄚ8)
  3. #73
    Arcus的超強撥放機,Euro 4000,去年就發表了,我居然沒留意,大家可上網看看
    Arcus also show the new Incantare media server, which is said to play and record Blu-ray Discs, have decoding for "all the new audio formats," include a DBS tuner, and have a variety of inputs on its back. The Incantare retails for 5000 €.
    media server就是一台電腦,從後面看更清楚。看看它的technical data sheet連配置都一目了然:)
    arcus incantare: MediaServer – technical data sheet
    MediaServer
    Frequency response 2 Hz - 20 kHz
    Distortion factor < 0.002 %
    Channel separation > 110 dB
    Signal-to-noise > 110 dB
    Audio inputs analogue 1 x stereo cinch
    Analoge Audio-Ausgänge High definition 7.1 multichannel, 1 x stereo cinch
    Audio outputs analogue SPDIF toslink, 24 Bit, 196 kHz
    Video outputs HDMI 1.3, DVI-I
    Weight 20 kg
    Dimensions incl. feets 44 x 10 x 37 cm
    Power supply 110 / 230 Volt; 50 - 60 Hz
    Optional extras Extern memory up to 4 TB
    Disc drive Selectet high end slot in drive
    Used memory audio/video formatted memory with damped suspension
    Memory size 1 TB, 4 GB RAM
    Backup function Yes
    Cooling Heatpipe System without fan
    Networking wired Ethernet 10/100/1000 m/bits
    Networking wireless By USB-stick
    Encryption Folowing Rules
    Other ports 6 x USB 2.0
    Finishes Titan silver, black, white
    Mechanical construction Resonance optimized full metal housing, shielded board,
    vibration decoupled, stream optimized
    Technology platform Microsoft Windows Vista Ultimate Certified for Dolby Home Theater,
    Microsoft Windows Vista Premium WHQL
    Processor Intel Core 2 Duo E8500, 3,16 GHz
    Audio resolution 24 Bit - 196 kHz
    Video resolution 1080p Full HD, 2048 x 1536 mit 75 Hz frequence (QXGA) for digital
    and analog screens, HDCP Version 1.1 support
    Supported media BD-RE/R (SL), BD-RE/-R (DL), BD-ROM (SL/DL), DVD Multi Read/
    Write support, CD-R/-RW-ROM
    Audio support MP3 (32 kBit/s - 320 kBit/s), WAV, WMA, Audio CDs
    Video support MPEG-2, VOB, ASK, M1V, M2V, WMV, DAT, VOR, DVR-MS, H.264,
    MP2, MOV, DV AVI, VC1, TS, TRP, TP, M2TS, RM, DivX AVI
    Supportet formats TCP/IP, UPnP AV, DHCP, AutoIP
    Supported data systems FAT, FAT32, NTFS
    Country of production/manufacture Developed and engineered in Germany
  4. #74
    引用 作者: musk 查看文章
    New flagship model: Raven Black Night:P
    http://www.tw-acustic.de/engl/000001...304/index.html
    真特別!!!!!!!!!!!:O:P
    不知0.5大約要多少~~~:*
  5. #75
    引用 作者: 小佐 查看文章
    真特別!!!!!!!!!!!:O:P
    不知0.5大約要多少~~~:*
    小郭上ㄚ!!!
    那台旗鑑的讚啦!!!
  6. #76
    剛發佈的break-in機器,國內已有代理商在談了,過一會大家就可看到了
    不知我有沒有看錯!又邊那個好像是『洗刷刷』勒...
    該不會拿來break-in 耳朵用的吧..
    聽之前...洗刷刷..洗刷刷...
    這麼大一根掏耳棒...(sweat)會要命拉...
  7. #77
    Day 2 Highlight
    第1天一整個累掛,坐了15個小時以上的飛機直奔會場,還好早餐有補充
  8. #78
    一進會場就遇到Esoteric的社長與海外經理,今年的新東西就是SA-50,以我的經驗他們在會場的時間應該不多,先拍個照
  9. #79
  10. #80
    Focus 110 A 主動式喇叭,白色的很漂亮,現場用iPod當訊源
