目前是愛爾法代理的,不過不便宜,市面上好像已經沒貨了.....
不過這裡可以試試
作者: PAGANINI-KK
請問小葉兄,這三張那兒有賣!!謝謝!!
作者: PAGANINI-KK
請問小葉兄,這三張那兒有賣!!謝謝!!
經詢問過,Joy Audio好像還有貨可去電詢問看看~
是喔,我問就沒貨...;(
今天還到合友與佳佳去找說..:(
作者: musk
作者: 小葉
是喔,我問就沒貨...;(
今天還到合友與佳佳去找說..:(
我也忘了這系列我當初一張買多少錢,小葉知道約略價格嗎?
作者: PAGANINI-KK
請問小葉兄,這三張那兒有賣!!謝謝!!
今天去世貿看音響展時去音橋攤位逛時剛好看到 ALR JORDAN / Voices the collection 這張,看側標是音橋代理的,立刻收起來. 重點是還真的蠻好聽,現在好好享受中.
個人比較常用的是Densen DeMagic與AYRE/CARDAS SYSTEM ENHANCEMENT DISC(大都用Track 7 Full Glide) [約每週同時使用這2張一次]
Densen DeMagic另有一個不為人知的功用是可用來調整喇叭擺位進而調整相位
"Irrational, But Efficacious", the System Enhancer Disc from Ayre Acoustics, Inc. is excellent in breaking in components and cables, integrating sub-woofers with other loud speakers and features both a short and full glide tone sweep. "Tune up" your system in under 20 minutes!
The main tool is a five minute glide tone, that when played through your system at a moderately low listening volume, will improve its sound. While we don't have conclusive proof of the mechanism involved, we suspect that it functions by demagnetizing residual fields that build up in your components over time. We recommend playing this track on a periodic basis, from perhaps once a week to once a month. We put this track at the end of the disc so that it can be easily played even if the system is unattended. The other tracks have more specialized functions.
The tracks on this disc were created digitally with 88.2 kHz, 32-bit resolution. Enhanced resolution transfer to the 44.1 kHz, 16-bit CD format was performed using 0.5 bits of dither with a triangular probability distribution function for maximum fidelity.
Selections:
Short Glide Tone: This 60-second track contains a 45-second glide tone that sweeps from 5Hz to 20kHz, preceded by 5 seconds of silence and followed by 10-seconds of silence. This track offers a quick system "tune-up" for those times when you just can't wait five minutes for the full glide tone.
White Noise: Uncorrelated stereo white noise with a peak level of -12 dB. White nosie is purely random in nature and is chiefly used with test instruments for specialized measurements. The track lasts for 180 seconds and features a 2-second fade in and fade out.
Pink Noise: Uncorrelated stereo pink noise with a peak level of -6 dB. Pink noise is low-pass filtered to achieve equal energy in each octave, and is also commonly used with test instruments for specialized measurments. The track lasts for 180 seconds and features a 2-second fade in and fade out.
Brown Noise: Uncorrelated stereo brown noise with a peak level of -3 dB. Brown noise is low-pass filtered to closely mimic the spectral distribution of music. This signal is excellent for use in breaking-in components and cables. The track lasts for 180 seconds and features a 2-second fade in and fade out.
Mono Brown Noise: Identical noise signals in both channels. This track can be very useful when integrating sub-woofers with other lous-speakers. The track lasts for 60 seconds and features a 2-second fade in and fade out.
Out-Of-Phase Brown Noise: Opposite-polarity brown noise signals in each channel. This track can be used to minimize the actual sound levels when breaking-in equipment, due to acoustic cancellation between the channels. The overall sound level will be minimized when two loudspeakers are placed as close together as possible.
Full Glide: This 300-second track contains a 285-second glide tone that sweeps from 5Hz to 20kHz, preceded by 5 seconds of silence and followed by 10 seconds of silence. Please be sure to play the entire track without interruption. Try it, you'll like it!
LP則使用CARDAS MK2 FREQUENCY SWEEP AND BURN-IN RECORD
The Cardas Frequency Sweep and Burn-in Record is a unique tuning tool for system set-up, diagnostics and maintenance. It was produced by George Cardas and mastered by Stan Ricker. The "Sweeper", in addition to the standard tones, includes relative and absolute polarity checks, vocal channel identification and frequency sweeps that ultrasonically clean the cartridge stylus and degauss the entire system. And, locked, pink noise grooves that repeat endlessly, blank plateaus, even a sync label to check platter speed. All on a 180 gram pressing with a smiling Stan cover.
Selections (Sweeper):
1000 cycles, -14db
Sweep 30Hz to 30KHz, -14db, 2 ch., in phase
Sweep 1KHz to 30KHz, -14db, 2 ch., out of phase spiral
Sweep 1KHz to 30KHz, -14db, 2 ch., out of phase lock out
10KHz, -14db, 2 ch., in phase
10KHz, -14db, left channel
10KHz, -14db, rich channel
1KHz triangle wave, -14db, 2 ch., in phase
1KHz, -14db, 2ch., in phase
1KHz, -14db, left channel
1KHz, -14db, right channel
400Hz, -14db, 2 ch., in phase
400Hz, -14db, left channel
400Hz, -14db, righ channel
65.4Hz, 2 ch., in phase, lock out
65.4Hz, 2ch., out of phase, spiral
49Hz, 2 ch., in phase, spiral
49Hz, 2 ch., out of phase, lock out
1KHz, "0"db for level set.
Selections (Burn-In):
Greetings from left channel
Greetings from right channel
Greetings from both channels
In Polarity, both channels, positive polarity
Out of Polarity, both channels in negative polarity
13 strikes on a high "B-Flat" on a piano
Hollow sticks (various length and diameter) being struck against each other
20 locked grooves, lateral modulation (mono)
32 locked grooves, vertical modulation (out of phase)
26 unmodulated grooves.
還有一張聖經Chesky ULTIMATE DEMONSTRATION DISC (不過這張我很少使用)
Reading about transparency or focus will only take you so far, the Ultimate Demo Disc serves as an aural dictionary by cueing the listener to specific sonic qualities of each selection. By consistently using the Disc, hearing & understanding these terms will become so much easier. The Disc can be used to evaluate speakers, receivers, preamps, power amps, CD players, digital to analog convertors, even cables. Artists on this disc include: Rebecca Pidgeon, Ana Caram, Leny Andrade, Sara K., Monty Alexander, Johnny Frigo, Fred Hersch Trio, Livingston Taylor, & more! Demo's include: High Resolution, Transparency, Holographic Imaging, Focus, Midrange Purity, Depth, Transients & many more!
Features:
• High Resolution Technology - 128x Oversampling
Selections:
1. Welcome to the Ultimate Demonstration Disc
2. High Resolution - Introduction
3. Spanish Harlem - Rebecca Pidgeon
4. Depth - Introduction
5. If I Could Sing Your Blues - Sara K.
6. Atmosphere - Introduction
7. Maiden Voyage - Leny Andrade
8. Midrange - Introduction
9. Grandma's Hands - Livingston Taylor
10. Naturalness - Introduction
11. Correnteza - Ana Caram
12. Transparency - Introduction
13. Played Twice - The Fred Hersch Trio
14. Presence - Introduction
15. Ask Me Now - McCoy Tyner & Joe Henderson
16. Visceral Impact - Introduction
17. Sweet Georgia Brown - Monty Alexander
18. Rhythm & Pace - Introduction
19. I Love Paris - Johnny Frigo
20. Focus - Introduction
21. Vivaldi's Flute Concerto in D - performed by the Connecticutt Early Music Festival Ensemble
22. Holographic Imaging - Introduction
23. Britten's Festival Te Deum - performed by the Westminster Choir
24. Transients - Introduction
25. Stravinsky's The Royal March - performed by Solisti New York conducted by Ransom Wilson
26. Bass Resonance - Introduction
27. A Selection from Best of Chesky Jazz and More Audiophile Tests, Volume 2
28. Dynamic Test - Introduction
29. A Selection from Best of Chesky Jazz and More Audiophile Tests, Volume 2
30. Final Announcement
另一張 CHESKY/STEREO REVIEW GOLD STEREO & SURROUND SET-UP DISC CD
Stereo Review and Chesky Records have teamed up to help maximize the performance of your home stereo or home theater system with audiophile tests illustrated by selections from the finest music Chesky has to offer.
This Set-Up Disc from Chesky Records is mixed from a Gold master. Producing from a Gold master features less noise jitter and a purer sound!
Selections:
1. Introduction
Section One:
2. System Phase
3. Phase Test Intro
4. Phase Test
5. Music Intro
6. Under The Table - Rebecca Pidgeon
Section Two:
7. Stereo Speaker Setup
8. Channel Balance Test Intro
9. Channel Balance Test
10. The Stepped Stereo Pan Test Intro
11. The Stepped Stereo Pan Test
12. Music Intro
13. Agua De Beber - Ana Caram
Section Three:
14. Subwoofer Setup
15. The Subwoofer Level Matching Test Intro
16. The Subwoofer Level Matching Test
17. Shake, Rattle, And Roll Test Intro
18. Shake, Rattle, And Roll Test
19. Music Intro
20. Leather Cats (excerpt) - Oregon
Section Four:
21. Imaging and Soundstaging
22. General Image and Resolution Test from The Best Of Chesky Jazz and More Audiophile Tests Volume 2
23. Music Intro
24. Piano Concerto No. 27 - Allegro (excerpt) - W.A. Mozart
25. Music Intro
26. Psalm 24 - Lili Boulanger and the Westminster Choir
Section Five:
27. Room Acoustics and System Response
28. The Clap Test Intro
29. The Clap Test
30. The Wandering Audiophile Intro
31. The Wandering Audiophile
32. Music Intro
33. Pau Brasil - Badi Assad
34. Aires Del Poliogono - Carlos Heredia
Section Six:
35. Home Theater System Check
36. Dolby Pro Logic Circular Pan Test Intro
37. Dolby Pro Logic Circular Pan Test
38. Dolby Pro Logic Center To Surround Pan Intro
39. Dolby Pro Logic Center To Surround Pan
40. Dolby Pro Logic Channel Identification Intro
41. Dolby Pro Logic Channel Identification
42. Theater Without Pictures Intro
43. The Soldier's Tale - Joseph Laments his Fate - Igor Stravinsky (Solisti New York)
Section Seven:
44. The Music Tests
45. Theme From I Love Lucy - Paquito D'Rivera
46. Music Intro
47. Gadamaylin - I Ching
48. Final Announcement
有進一步的資料可以提供一下嗎 :P
作者: kafka
怎麼沒人提到triangle 那張…
