第26頁,共29頁 第一第一 ... 162425262728 ... 最後最後
顯示結果從 251 到 260 共計 284 條
  1. #251
    看來Ayre在High End市場做得不錯,少見持續在穩定成長的....
  2. #252
    問題
    找到了張屁股的碟照,上面四個BNC頭不知啥用?:P
  3. #253
    看不到文字,不知道是輸出還是輸入了。
  4. #254
    Ayre Acoustics VX-R Stereo Amplifier
    • 01 Jan 12
    • Written by Doug Schneider
    • Text Size: Decrease Reset Increase
    Note: Measurements performed by BHK Labs can be found through this link.
    Solid-state amplifiers are often the least inspiring components to review. Not all solid-state amps sound the same, as some would have you believe, but many sound quite similar to each other, and few have a sound that really lights my fire. It’s probably because of this “sameness” that so many still swear by tube amplification, not to mention the fun that can be had by mixing and matching different models of the same tube type, aka tube rolling. As for controls, most power amplifiers have a power button, maybe a standby switch, and a little light somewhere that tells you it’s on. Not that much to talk about. Finally, high-powered amps are usually big, which wouldn’t be so bad if so many of them -- even some really expensive ones -- weren’t also chunky, clunky eyesores. So ask me to a review a solid-state power amplifier, and my first response is normally, “Is there anything else in the queue?”
    This time, there was no hesitation. Enter Ayre Acoustics’ VX-R stereo power amplifier ($14,950 USD).
    http://www.soundstage.com/index.php?...views&Itemid=4
  6. #255
    小弟再問個問題
    ayre k3 前級有唱放的,外觀看的出來嗎
    小弟爬圖片看不出差異性
    ayre的唱放板要多少錢
    感謝.......
  7. #256
    酷
    從外觀看不出分別,只有打開內部,帶唱放的中間有塊正方的線路板(沒有的話是一條細長的多個電阻板)。
    http://bbs.hifi168.com/showtopic-91645-118.aspx
    鏈接有說明給您參考。
    價格不清楚,作為選配件,k1的唱放板是1600美金(發售價),日本中古市場k3有無唱放價格差10萬日元左右,給您參考。
  8. The Following 2 Users Say Thank You to anfield For This Useful Post:
  9. #257
    小弟剛剛入手AX-7
    現在有一個問題請教...
    它的PP功能,小弟都依步驟操作,也出現PP的字樣,可是當使用時主聲道卻都沒聲音出現,又來回試了幾次(換輸入端 OR 解除PP模式再重新操作成PP)也都無效
    之前使用MARANTZ PM-14SA的時候,用它的旁通後級功能都很正常... 請問哪個前輩有類似經驗,或知道問題出在哪>>>>>麻請指導小弟
    感謝!!
    而對於一些同時使用二聲道與多聲道系統的用家而言,AX-7也特別內建了「Processor
    Pass-Through」(訊號直通)功能以利使用。您只要擁有DVD、多聲道SACD或DVD-Audio訊源,任選一組輸入連接(平衡與非平衡皆可),接著拔掉電源--訊源或AX7的電源
    ,等待至少10秒後按著被連接之訊源輸入鈕不放--是訊源或AX7D
    ,再度插上電源即可。此時螢幕上會顯示「PP」(Processor
    Pass-Through)字樣,此時的音量調整就會轉交由環繞前級加以控制.
  10. The Following User Says Thank You to raychen For This Useful Post:
  11. #258
    引用 作者: raychen 查看文章
    小弟剛剛入手AX-7
    現在有一個問題請教...
    感謝!!
    有沒有可能是因為另外接的前級輸入選擇沒選對?
    曾經我接過其他器材時因為這樣而沒出聲,可以再檢查看看。
  12. The Following User Says Thank You to hidoson For This Useful Post:
  13. #259
    經過確認,來回檢查,努力之後....還是沒解決!!!
    有人有過類似經驗嗎....
    還是感謝hidoson兄
    引用 作者: hidoson 查看文章
    此篇文章於 2012-03-03 08:50 PM 被 raychen 編輯。
  14. #260
    這兩天又陸續試了幾次,發現並不是完全沒有聲音,開啟PP(劇院模式)時,是有非常小的聲音的,要耳朵非常靠近喇叭單體才聽的到,而且劇院前級(SONY E9000ES)聲音要轉到一點鐘方向才會有些微得聲音出來,我想這樣是不正常嗎?
    還是AV前級和AX-7不能匹配呢?
    請前輩高手幫小弟把把脈...
    引用 作者: raychen 查看文章
    小弟剛剛入手AX-7
    現在有一個問題請教...
    感謝!!
