第18頁,共166頁 第一第一 ... 816171819202868118 ... 最後最後
顯示結果從 171 到 180 共計 1660 條
  1. #171
    最近又看到一些資訊
    Ten Questions about Computer Audio with Vincent Sanders and John Hughes of VRS Audio Solutions
    裡面提了10個關於電腦訊源的疑問和看法
    其中一個提到關於rip音樂用的軟體還有光碟機對聲音的影響
    裡面有提到用macbook的光碟機和iTunes來rip音樂並不是很理想
    所以不知道Eton大還有其他用mac的燒友都是用什麼軟體和光碟機來rip音樂以達到最好的效果?:)
    3. Let´s move on to ripping. As with the above, there are proponents that claim only certain software, and optical drives for that matter, can "accurately" rip a CD. That they can clearly hear differences between rips via different means; even though the rips are bit for bit perfect. Any thoughts on what is going on here? Is there an advantage to using specific ripping software or drives over another? Say iTunes, WMP, Max or whatever when compared to say EAC?
    We are still investigating this subject, so we don't have any definitive results to give at this time. Exact Audio Copy or EAC does produce better sounding rips than iTunes or Windows Media Player. It's pretty easy to do a listening test to determine for yourself. We have had many listening tests with skilled and unskilled listeners, and more than 80% of the time listeners preferred the EAC rips. There are other ripping engines that sound as good or better than EAC as well, like dbPoweramp Ripper, CDex etc.
    The CD/DVD drive used for ripping does make a monumental difference in sound quality and the ability to get a bit perfect rip (Secure). We generally like external USB or Firewire connected drives like Pioneer or Teac for ripping. Getting the drive out of the computer case and using it's own dedicated power supply, does tend to make a difference. Also, the drives used in Mac Books are generally poor for ripping, and does not handle the stress of re-reading sectors that bit perfect ripping requires.
  2. #172
    目前公認較好的大概有Yamaha與Plextor scsi CD-ROM(不過皆停產已久)
  3. #173
    感謝MUSK大的回覆 不知道您有沒有其他推薦的外接式光碟機
    引用 作者: musk 查看文章
  4. #174
    引用 作者: Steven6 查看文章
    Plextor Premium 2U (CD-R/RW)
    http://plextor.jp/pc/products/premium2u/features.html
    新搭載機能 ヤマハ株式会社の技術「AudioMASTER™」機能
    ヤマハ株式会社のCD-R/RWドライブに搭載しておりました高品質書き込み機能「AudioMASTER™」を本製品「PlexTools Professional」に採用いたしました。
    AudioMASTER™とは、CDフォーマットの可能性を限界まで引き出す高品質記録機能です。
    CD-Rディスクの記録エリアをぜいたくに使用して記録するピットやランドを長くとり、再生時に品質を低下させる原因となるジッターを最小限に抑えます。データの保存性が高く、カーオーディオなどでの再生もより確実となります。
    音響コンデンサ 搭載
    書き込み品質向上のために、ELNA社 音響用アルミニウム電解コンデンサを搭載いたしました。
    電源周りに使用することで、電源のノイズを低減し、クリーンな電流を各サーボ回路に供給し、高品質で低ジッターな書き込みを可能としました。
  5. #175
    引用 作者: musk 查看文章
    請問musk兄:
    我還有一台Plextor scsi CD燒錄機,日製的,12倍燒錄,32倍讀取服役中。
    Plextor scsi CD-ROM 40倍讀取也服役中,這台是大陸製的,所以很適合來rip嘛?
  6. #176
    引用 作者: musk 查看文章
    音響コンデンサ 搭載
    馬哥哥~這東西台北買得到嗎 ? 聽說 還像缺貨很久耶 :*(sweat)
    虛空有時盡 我願仍無窮
  7. #177
    引用 作者: kib71350 查看文章
    這個找代購從日本買比較快! 還是你要發個團購?!:P
    http://kakaku.com/item/K0000036955/
  8. #178
    ㄟ~~很想啦~~但是心有餘力不足啊
    虛空有時盡 我願仍無窮
  9. #179
    關於後級電扇
    Eton使用的是變壓器
    有兩頭可插
    一頭顯示110V,一頭顯示220V
    (降壓)
    市電插在220V端,輸出插110V端,那電壓就會變成 55,若是台電的電壓夠準的話
    (升壓)
    相同的道理
    市電插在110V端,輸出插在220V端,那電壓就會變成220V,一樣若是台電的電壓有準的話
  10. #180
    關於後級電扇
    Eton使用的是變壓器
    有兩頭可插
    一頭顯示110V,一頭顯示220V
    (降壓)
    (升壓)
    相同的道理
    補圖!當初有拍到!
