第57頁,共158頁 第一第一 ... 747555657585967107157 ... 最後最後
顯示結果從 561 到 570 共計 1578 條
  1. #561
    Pluto Audio 12A Standard turntable with 6A arm
    €14000
  2. #562
    €14000
    威致精密的石墨唱片鎮
  3. #563
    (株)ユキムは、S.S Laboratoriesのアナログレコード用スタイラス(針先)クリーナー「Stylus Fine」を3月に発売する。価格は税込で5,985円。
    Stylus Fine
    本製品は強力な洗浄力を持たせながら、試聴を繰り返しつつ音質を検討してきたというレコード針保護洗浄剤。スタイラスチップに固着した頑固な汚れも落とせるという。1ボトルで約50回分の使用が可能。
    クリーニング時には2本付属している付属のスタイラスクリーニングスティックを使用し、先端スポンジに洗浄液を含ませて洗浄する。カンチレバー内への洗浄液の侵入も防ぐ構造にしているという。
  5. #564
    Pathe Wings Turntable and Record Clamp
    PW 07 Walnut
    Our many years experience in audio systems construction made us discover the secret of a high quality sound reproduction and create Pathe Wings turntables. Warm sound and deep dynamics will titillate your senses and transport you into a different dimension of reality. Our product is an example of precise solid work for those who appreciate natural sound. Well matched components dampen vibrations and acoustic feedback which influence adversely turntable sound quality.
    Pathe Wings turntable is painstakingly made of components produced from five different materials, each of different density: MDF, HDF, wood, plywood and alloy of high density metals exceeding 10 000 kg/m3: "Pathe Wings" brainchild. Precise balance is provided by adjustable cones, made of 8700 kg/m3 density brass. Combination of these elements assures low ratio of energy storing and high ratio of damping unwanted vibrations. That's why Pathe Wings assures the high quality sound reproduction. Drive and chassis come form the cult Thorens turntables, still used by Linn.
    650 gram
    Type of Steel: high quality steel - non magnetic
    fi: 80 mm
    height: 36 mm
    Another measure taken in order to reach high-end sound is record player clamp. Pathe Wings record player clamp makes records fit tighter to the turntable, significantly improving the sound quality.
    Pathe Wings
  7. #565
  8. The Following 4 Users Say Thank You to Leo Yeh For This Useful Post:
  9. #566
  10. The Following 2 Users Say Thank You to Leo Yeh For This Useful Post:
  11. #567
  12. The Following 2 Users Say Thank You to Leo Yeh For This Useful Post:
  13. #568
  14. #569
  15. #570
    Cliccare le foto per ingrandirle.
    Click to enlarge photos.
    直接在图片上点击放大.
    10.01.12
    Simon Yorke Series 9 turntable
    http://www.remusic.it/index.php?Mast...rif=fd7e1967c9
  16. The Following User Says Thank You to Leo Yeh For This Useful Post:
