Detachable headshell:
Made of ca. 40 plies of the same carbon fiber fabrics as the arm wand, it is extremely rigid and light. Using the same material improves the vibration energy transfer from the headshell to the arm wand.
Carbon fiber is conductive, thus making possible to ground the cartridge through the arm wand.
The headshell can be rotated to set azimuth; there is a scale with zero and reference markings to aid in the process. It is possible to remove the headshell and replace it with others of different sizes, geometries and mass to match them to specific cartridges.
A very substantial clamp firmly anchors the headshell to the arm wand and provides rigidity.
For the Customer who so wishes, an option with fixed headshell is available.
SAT Protective Transport Case
The SAT is delivered in a very high quality - USA manufactured - protective case with high density foam cutouts. The arm can be safely shipped around the world and stored together with its ancillary equipment.
Together with the arm, a pair of counterweights, bearing adjustment tool, arm base, arm rest, alignment template and accessories box are supplied.
The SAT has a continuous run of cable, terminated with the length and choice of terminals the Customer specifies.
Many of the setup operations can be performed using the case as holder for the arm. This improves the ergonomics and reduces the risk of damaging the arm during the delicate steps of mounting the cartridge and its connectors, and balancing the arm.
The transport case is dimensioned to accommodate the 9" and 12" versions of the SAT pickup arm.
Composite arm wand.
Manufactured in 1-piece with carbon fiber pre-preg, cured in autoclave under pressure and temperature. It has variable thickness and cross section to provide high rigidity and keep the moment of inertia at levels compatible with today´s cartridges.
I dare to state my arm wand is much more rigid than any existing arm of the same length and mass. This enables the arm to vibrate with less amplitude when the cartridge is tracing the record, which translates in more accurate signal reproduction.
The arm wand is covered with a polymer sleeve providing damping.
The Following 3 Users Say Thank You to Leo Yeh For This Useful Post:
這個免費的軟體iRPMhttps://itunes.apple.com/us/app/irpm/id406885844?mt=8 還蠻好用的。拿來測唱盤轉速還挺方便的。前兩天,我試著用日光燈(我是用省電燈泡)和 strobe disc。搞的人仰馬翻也測不出來。大概我眼睛的散光太嚴重,怎麼看都是連成一片的。用這個app,把iPhone放在轉盤上。哈!一下就出來了。當然這個準確度可能只到小數點後一位左右。不過,拿來作個第二個參考點還不錯。
The Following 2 Users Say Thank You to kevintran For This Useful Post:
Vertere Reference Record Player
根據使用的唱臂不同,有三個版本,最昂貴版本用的是之前有介紹過的天價唱臂Vertere Reference Tonearm。
【新品消息】 3.5萬美金的唱臂: Vertere Reference Tonearm: http://www.my-hiend.com/vbb/showthre...614#post193614
There are 3 versions:
Prices in SEK.
SG-1 Standard - 124,000
RG-1 Standard which uses the better bearing - 160,000
RG-1 Reference, bearing like RG-1 Standard, but also uses the best external PSU - 232,000
SG - Standard Grove and RG - Reference Grove
Tonearms:
SG-1 - 17,000
RG-1 - 40,000
Reference - 264,000
The Following User Says Thank You to Ted Chen For This Useful Post:
MG1 with SG tonearm 已上市, 獲得好評,值得注意!!
The Following User Says Thank You to 上瑞張sir For This Useful Post:
Lautlos Rein LP washing machine
http://www.lautlos-rein.de/
