第40頁,共158頁 第一第一 ... 3038394041425090140 ... 最後最後
顯示結果從 391 到 400 共計 1578 條
  1. #391
    將軍兄的器材不論是類比或數位都是相當高水準的,其箇中滋味主人是最清楚了解的!
    因此此句話由將軍兄來說就更加貼切真實啦!:)(y)
    引用 作者: 將軍 查看文章
    CD,LP,二種都很好!!:)
  2. The Following User Says Thank You to oscarwu For This Useful Post:
  3. #392
    引用 作者: 將軍 查看文章
    GRAHAM和SME有些能通用(9"臂);
    其餘廠牌之間,幾乎沒有通用的規格!!
    LINN 的三孔臂板,有些唱臂可用,
    如 DYNAVECTOR ,KUZUMA,CLEARAUDIO..
  4. The Following 2 Users Say Thank You to hojuiyang111 For This Useful Post:
  5. #393
    圓的三孔螺絲位置好像有~大三孔和小三孔~~~:O實際實在不了~~:(
  6. #394
    Robert Johnson - The Complete Original Masters - Centennial Edition
    Robert Johnson - 100th Birthday Box Set
    10-inch 45-RPM Replicas of Original Vocalion Records Plus Bonus CDs and DVD
    ONLY 1,000 COPIES PRESSED
    Acoustic Sounds Exclusive
    This isn't a recommendation; it's a declaration: Miss This One And You'll Be Sorry!
    http://store.acousticsounds.com/d/74...words=NL041111
  8. #395
    Fleetwood Mac Rumours, 45rpm, 2 LP reissue releasing on April 16, 2011:
  9. The Following 2 Users Say Thank You to Edgarhorns in LA For This Useful Post:
  10. #396
    最近收的幾張黑膠
    還在等Camel的Snowgoose (應該快寄到了). 對我來說,黑膠的最大好處是可以很便宜的買到以前聽過但是買不到/買不起的摇滾LP.
  12. #397
    Thales Tonearm Turntable (TTT)
    We decided that the extraordinary design and performance of our tangential pivoted tonearms required a fitting turntable. The newly designed Thales Turntable (TTT) is made to match our tonearms perfectly in all aspects: technically, optically and tonally.
    Based on the experience that a turntable with its tonearm should be one single unit, we have created a modular system that is flexible but looks harmonic as well. Each of the 125 parts has been carefully designed to perform its function perfectly.
    A precision brushless motor is coupled to the platter by a short belt. The whole drive system is arranged underneath the platter. The motor is driven by a specifically designed analogue power unit and this is housed in a separate case. The main bearing combines traditional craftsmanship with modern materials: rotational guidance is controlled by two brass elements, treated with diamond-tools, while the vertical force is supported by a spherical carbide element.
    The TTT comes with a spring-loaded clamp mechanism. This ensures the contact between the record and the platter is the same all over. Three decoupling ball element feet support the whole turntable; these allow excellent decoupling of the turntable. The TTT can be configured to allow one or two tonearms to be fitted and it comes in an elegant black finish with silver edges.
    Technical Specifications:
    - Turntable speed: 33rpm, 45rpm
    - Wow and flutter at 33rpm, DIN45 507: ±%
    - Rumble: incapable of measurement
    - Voltage: 240/120V, 50/60Hz
    - Tonearm: maximum 2, customized bases available.
    - Output-terminals: RCA / XLR / DIR
    - Weight: 18.5kg
    - Size: 432 x 312 x 105mm
    Turntable Specifications:
    - 3-phase motor underneath platter
    - Short belt drive system with flywheel
    - High-precision bearing, hard chrome-plated
    - Clamp with spring loaded flattening-mechanism
    - Lead-vinyl-mat between the platter and the record
    - Decoupling ball element feet
    - Separate power supply unit
    - Black finish with silver edges
    http://www.tonarm.ch/
    音響技術3個人買單?!
    http://www.tonarm.ch/uploads/images/...otechnique.pdf
  13. #398
    [恕刪]音響技術3個人買單?!
    有沒有那個開路先鋒要試試最便宜的 Simplicity:
    我沒事買了一大堆殺LP的LP,結果手上一大堆『專殺AB點』的LP,A點好聽的B點給我死當,B點好聽的A點給我擺爛;但是直切臂又太貴、太複雜了難以實踐,有沒有那個高手買這個下來的?我挑幾張專門殺AB點的LP來測測看能不能取代直切臂.....:)
  14. The Following User Says Thank You to psycho For This Useful Post:
  15. #399
    我已經入庫了!!
    但不用殺甚麼,因為買這支的原因就只是想買罷了!!:o
  16. The Following 4 Users Say Thank You to 將軍 For This Useful Post:
  17. #400
    哇..........點到名的就有............
