第48頁,共158頁 第一第一 ... 3846474849505898148 ... 最後最後
顯示結果從 471 到 480 共計 1578 條
  1. #471
    Suzane Vega這張除了甜美的人聲外
    B面有充滿低頻的能量,值得測試系統喔
    上面第一張照片,右上角的CirKus的One專集,讚!可惜這個團好像沒出過幾張專集。
    昨晚聽CirKus,Suzane Vega,和Rossington Collins Band;這幾張的狀況都很好,只用唱片刷掃一遍,就沒什麼雜音了。
    Suzane Vega的那張真不錯,每一首歌都是一個小故事。
    另外值得一提的,Suzane Vega和Jade Warrior的兩張唱片都是DMM (Direct Metal Mastering)的。
  2. The Following User Says Thank You to VINCENTLEE For This Useful Post:
  3. #472
    最近收到幾張二手唱片
    Kraan是個前衛樂團(我以前也沒聽過)。那張Shefield Lab的也不貴(10美元),買來看看倒底燒在那裡。
    聽聽這首演奏曲
    http://www.youtube.com/watch?v=RZDH-...f=list_related
  5. #473
    同一批還買了這幾張
    抱歉,我以前也沒聽過這位樂手。不過,挺合我味口的。來聽歌
    http://www.youtube.com/watch?v=8-8ZhhGEf3c
  6. The Following User Says Thank You to kevintran For This Useful Post:
  7. #474
    預設 奇蹟 重出江湖
  8. The Following 5 Users Say Thank You to acapellaaudio For This Useful Post:
  9. #475
    FXR II
    We believe F•X (pat pend) a milestone in arm design.
    (F•X is pronounced: F dot cross)
    Is FXR II now the the best arm in the World?
    (...Perhaps not as fantastic a claim as you might think. Read on)
    http://www.thefunkfirm.co.uk/arms/fxr_II.html
    F•XR II ($1995)
  10. #476
    預設 黑膠狂老爹(徵求完整翻譯)(繁中)
    不知道網兄有沒有看過了沒...
    黑膠狂老爹(徵求完整翻譯)(繁中)
    http://www.youtube.com/watch?v=hXEoO...eature=related
    嚇死人的黑膠收藏!!~~
    據說有上百萬張...
  11. #477
    引用 作者: fyl0206 查看文章
    不知道網兄有沒有看過了沒...
    黑膠狂老爹(徵求完整翻譯)(繁中)
    嚇死人的黑膠收藏!!~~
    據說有上百萬張...
    記得在別的地方讀到:他的收藏偏向流行音樂,開價又太高。所以就......
  12. #478
    Analogue Alchemy Gloria Turntable
    Gloria - is even more superior turntable in our range of all-UK hand-built turntables, that is, again, a sophisticated, non-suspended record playing system. It has a unique construction and it is the biggest in our turntable range. As all of our turntables, Gloria has three stages, which are lined up as follows:
    Stage ONE is a single 20 mm high translucent or black hand polished acrylic TT base (other colours available on a special order), with a 40mm high frosted acrylic platter, high precision bearing, large solid steel and aluminium adjustable feet and shoes, supplied with an adjustable aluminium tonearm plate of your choice. All system is sitting on a matching 20mm acrylic isolation platform with aluminium / steel feet and shoes and fitted bubble level. The isolation platform comes together with the turntable as an integrated part of the system, or can be obtained separately.
    Stage TWO is a 40mm high single (TWO - S40) or a 20mm high dual base, separated by 20 mm high aluminium spacers (TWO - D20), translucent or black acrylic base (other colours available on a special order), with a 40mm high frosted acrylic platter, high precision bearing, large cylindrical solid aluminium and steel feet and shoes, with an adjustable aluminium tonearm plate of your choice. All system is sitting on a matching 20mm acrylic isolation platform with aluminium / steel feet and shoes and fitted bubble level. The isolation platform comes together with the turntable as an integrated part of the system, or can be obtained separately.
    Stage THREE is a 40mm high single (THREE – S40) or a 20mm high dual base, separated by 20mm mm high aluminium spacers (THREE –D20), translucent or black acrylic base (other colours available on a special order), with a 60mm high frosted acrylic platter, high precision bearing, large cylindrical solid aluminium and steel feet and shoes, with sandwiched aluminium adjustable tonearm plate with aluminium semi-cylindrical spacers to bring the armplate to required height. All system, including standalone motor, is sitting on a matching 20mm acrylic isolation platform with aluminium / steel feet and shoes and fitted with a handy bubble level. The isolation platform comes together with the turntable as an integrated part of the system, or can be obtained separately.
    Beautifully designed and striking looking GLORIA turntable can be obtained with two standalone 100mm diameter motor options: Stage I comes with a standard AC Motor, with speed adjusted by changing the belt position on the pulley. Stages II and III come with an advanced DC motor with separated electronic fine speed adjustments for 33 1/3 and 45 RPM. Any of three stages are very flexible and can take up to 4 arms: two of almost any arm – 9”, 10.5” or 12” arms, and two of up to 14” arms, if desired, with a special solid aluminium armboard of your choice, also used on our other models.
  13. #479
    Soundsmith Hyperion
    The Hyperion, Soundsmith’s new top-of-the-line moving-iron phono cartridge, utilizes a cactus needle cantilever. (That’s a cantilever made of a cactus needle.) Inspired by (the always dapper) Frank Schroeder and designed by Peter Ledermann, the Hyperion’s cactus needle cantilever provides both stiffness and damping—qualities which, according to Ledermann, had previously been mutually exclusive.
    Superior cantilever designs, Ledermann explained, have traditionally been tapered—a technique that’s difficult to accomplish with aluminum and even more difficult with extremely hard and durable materials such as boron, ruby, and diamond. Cactus needles, however, are naturally tapered, stiff, and durable, while their stacked fibers provide natural dampening.
    The Hyperion moving-iron phono cartridge ($7000) is available with Soundsmith’s CL or OCL styli, has a recommended tracking force of 1.8 to 2.2 grams, an output of 0.3mV, and is compatible with MC phono preamps. It is also available in a linear-tracking version, the Hyperion LT. Soundsmith guarantees the Hyperion for 10 years, and Peter Ledermann will retip the cartridge for free if it wears out within that time.
    “Other cantilevers are synthesized,” said Ledermann. “We grow these.”
    We listened to some music. The sound was not prickly or thorny at all. It was clean, clear, and immediate—bold and well-controlled—with vibrant colors and good senses of rhythm, touch, and scale.
  14. #480
    預設 唱放
    請問唱放在LP系統是否相對比較不重要?
    似乎比較少這方面的討論?
