第62頁,共90頁 第一第一 ... 1252606162636472 ... 最後最後
顯示結果從 611 到 620 共計 897 條
  1. #611
    預設 Cenya
    Cenya
    Cenya takes Penaudio into a new realm of monitors extending the dynamic range of Charisma and the purity and liquidity of Rebel 3. Musical, natural, open, three dimensional could be used to describe all Penaudio speakers, but Cenya conveys a magic never before heard. Whether one plays it loud or soft, Cenya mesmerizes you. There is only music. Natural and real.
    Penaudio’s new speaker design concept was first presented in their recently launched 2.5 -way floor-standing Sara. Cenya amplifies this movement strengthening Penaudio’s Finnish heritage and characteristics of craftsmanship, elegance and simplicity. This 2-way, 4-ohm monitor compliments any amplifier and sings with any genre of music.
    Tech Specs
    Type
    2-way, stand mounted, reflex loaded
    Drive units
    ¾”(20mm) ferrofluid cooled textile dome tweeter (Seas), 6”(145mm)magnesium coned midrange/bass (Seas Excel) with heavy copper rings above and below pole piece, radial reinforced surround
    Cross-over
    4000Hz
    Frequency range
    anechoic response +-3dB 45-28000Hz, in room response 40-25000Hz
    Sensitivity
    86dB/1m/2.83V
    Nominal impedance
    4ohms
    Recommended amplifier
    50+W
    Dimensions (WxHxD)
    (163x280x315)mm, (6,4×11.2×12,6) inches
    Weight
    8kg (17lbs)
    Special
    WBT binding posts, Jorma Design internal wiring, cabinet 19mm finnish MDF + with both sides veneered 1,5mm Penaudio Birch Plywood veneer
    Euro 3,000
  2. #612
  3. #613
    引用 作者: Mega 查看文章
    昨天去音逸找黃老大聊天
    又再聽了一次SitarII,這次是配Sara
    哇~~聲音真是美妙呀,我把Sara拿來配AV真是浪費啦,Sara真是一對好喇叭
    不過突然想到一件事,近期Penaudio的喇叭不論是2010年的Sara和2011年的Cenya
    都從以前的8歐姆變為現在的4歐姆
    這是為什麼呀??
    喇叭是設定為幾歐姆的對聲音上有什麼差異嗎??還是單純哪一部份的設計使然呢??
    一般喇叭的歐姆值都不是定值,基本上是隨著訊號的頻侓而改變。這個阻抗值從低於1歐姆到大於16歐姆都有可能。一般的標示是所謂的“額定阻抗”(nominal impedance),也就是在大部份的使用狀態是8歐姆或4歐姆。但是,這個數值跟好不好聲,甚至好不好推都沒什麼關係。比較有意義的話,應該是看從0~20KHz(或更高)的阻抗/相位角的變化。這和好聲沒很大關係,但是和決定擴大機的推力要求有關。
    額定阻抗變了,可能和分音器的修改,使用的單體不同,箱體設計改變有關。當然,上面這些東西改了,聲音當然有可能不同;變好變壞,那就只有聽過才知囉!
  4. The Following 8 Users Say Thank You to kevintran For This Useful Post:
  5. #614
    penaudio 新的website
    http://www.penaudio.fi/
    網站內 serenade 的介紹下方 有寫到
    "Serenade reviewed in taiwanese My-Hiend August/2008"
    小葉葛格和andy 葛格 舉世知名了
    虛空有時盡 我願仍無窮
  6. The Following User Says Thank You to kib For This Useful Post:
  7. #615
    Penaudio最新的原廠網站好像已經沒有Chara啦.....:(
    是否表示停產啦?還是要出新款的低音柱啦?|-)
  8. #616
    引用 作者: oscarwu 查看文章
    oscarwu 兄 ~ 那就快些把存貨買光啊 免得跟書架腳架般 .... :|
    虛空有時盡 我願仍無窮
  9. #617
    引用 作者: kib 查看文章
    這個事應該是音逸黃老闆要做的吧......
    假如Chara真的停產了,那現有用家中的Chara就有增值的空間啦....:o
  10. #618
    低音Chara 假如真的停產了..... 那會保值喔
    可惜沒那麼快啦
    已經請上瑞張sir問過原廠了
    > Dear Lee-Ming,
    > Chara is still in our program as you can see it in our
    > price sheets.
    > We haven`t had time to get it into our website. THere
    > will be plenty of more information about products and
    > Penaudio and me in future!
    > Thanks,
    > Sami
    放心過聖誕吧(music)
    Wishing you and your family a MERRY CHRISTMAS!!!
    音逸音響
    www.fineaudio.com.tw/news.htm
    電話:(02)2381-0586
    行動:0918-058 031
    一~五:中午1:00 ─ 晚8:00
    週 六 :中午2:00 ─ 晚6:00
  11. The Following 2 Users Say Thank You to 音逸音響 For This Useful Post:
  12. #619
    引用 作者: oscarwu 查看文章
    謝謝吳兄幫忙定貨:*:*:*
    Penaudio 回答Chara 沒停產.
    新網站還沒來的及維護(趕Cenya貨太忙, 台灣的訂單太大,順便
    感謝朱大咖的訂單:*).
  13. The Following 2 Users Say Thank You to 上瑞張sir For This Useful Post:
  14. #620
    朱大咖............最近很紅喔...........孔鎗孔鎗!
