第76頁,共90頁 第一第一 ... 2666747576777886 ... 最後最後
顯示結果從 751 到 760 共計 897 條
  1. #751
    Penaudio's newest design Sara S will be presented for the audience January 9-13 in Las Vegas (CES 2012/The Home Entertainment Show) and in Tampere (Sound Factor).
    http://www.penaudio.fi/products/floorstanders/sara-s/
    Type: 2,5-way, floorstander, reflex loaded
    Drive units: ¾” ferrofluid cooled textile dome tweeter (Seas), 2 x 160mm (6,5”) magnesium coned midrange/woofer, copper rings above and below T-shaped pole piece, radial reinforced rubber surround (Seas Excel)
    Cross-over: 300, 4500Hz
    Frequency range: anechoic responce +-3dB 45-28000Hz, in room 32-25000Hz
    Sensitivity: 86dB/1m/2,83V
    Nominal impedance: 4ohms
    Recommended amplifier:40+W
    Dimensions (WxHxD): (165x1030x290)mm, (6,6×40,6×11,4)inches
    Weight: 25kg (52 lbs)
    Specialities: Jorma Design wiring, Seas drivers, WBT 0730.12 (Signature platinum) pole screws, SCR polypropylene capacitors, Graditech air-core inductors, aluminium reflex pipe, custom made finnish birch plywood veneer 22mm / 16mm solid plywood cabinet
  2. The Following 4 Users Say Thank You to bigtree For This Useful Post:
  3. #752
    有著與最新大旗艦 Sinfonia 一樣的中低音......Seas Excel x兩支喔 :P
    音逸音響
    www.fineaudio.com.tw/news.htm
    電話:(02)2381-0586
    行動:0918-058 031
    一~五:中午1:00 ─ 晚8:00
    週 六 :中午2:00 ─ 晚6:00
  4. #753
  6. #754
    請問charisma的用家,是用那個amp??
  7. The Following User Says Thank You to sp007 For This Useful Post:
  8. #755
    Penaudio Charisma 與 Rebel 的用家很多都是搭配 AcousticPlan Sitar-MKII 管晶混血綜擴(特別版75W)
    此篇文章於 2012-01-18 03:46 PM 被 音逸音響 編輯。
    音逸音響
    電話:(02)2381-0586
    行動:0918-058 031
    一~五:中午1:00 ─ 晚8:00
    週 六 :中午2:00 ─ 晚6:00
  9. The Following 2 Users Say Thank You to 音逸音響 For This Useful Post:
  10. #756
    引用 作者: sp007 查看文章
    我是使用AcousticPlan Sitar-MKII
  11. The Following 4 Users Say Thank You to oscarwu For This Useful Post:
  12. #757
    Was browsing youtube. Found some new penaudio videos:
    Presentation of Penaudio 2012 lineup in Russia by Sammi!
  13. The Following 3 Users Say Thank You to bigtree For This Useful Post:
  14. #758
    Penaudio Sinfonia
  15. The Following 3 Users Say Thank You to bigtree For This Useful Post:
  16. #759
    Penaudio Speaker Design
  17. The Following 3 Users Say Thank You to bigtree For This Useful Post:
  18. #760
    請問penaudio的喇叭架還有得買嗎??
