第2頁,共482頁 第一第一 12341252102 ... 最後最後
顯示結果從 11 到 20 共計 4820 條
    謝謝Ducy兄的稱讚
  2. #12
    訊源:Ayre C-5xe universal stereo player
    www.ayre.com
    Features
    Discrete decoding and playback of all formats in their native domain.
    Zero feedback, DC-coupling, true differential balanced analog circuitry.
    Twin linear power supply design.
    Exclusive Ayre DSP software.
    PCM formats are “upsampled” to quad-rate at 24 bits, and then “oversampled” to 32x at 24 bits.
    Front panel LED display indicates format selected for DVD-Audio.
    Control port allows for connection to system controller )e.g., Crestron or AMX).
    Specifications
    Maximum Output Level
    2.05 V rms – unbalanced outputs
    4.10 V rms – balanced outputs (PCM)
    1.00 V rms – unbalanced outputs
    2.00 V rms – balanced outputs (DSD)
    Frequency Response
    DC - 20 kHz (44.1 kHz sample rate)
    DC - 22 kHz (48 kHz sample rate)
    DC - 40 kHz (88.2 kHz sample rate)
    DC - 44 kHz (96 kHz sample rate)
    DC - 80 kHz (176.4 kHz sample rate)
    DC - 88 kHz (192 kHz sample rate)
    DC - 100 kHz (2.8224 MHz sample rate)
    Output Impedance
    55 ohms – unbalanced outputs
    110 ohms – balanced outputs (55 per phase)
    Power Consumption
    60 watts maximum
    Dimensions
    17-¼" W x 13" D x 4-¾" H 44 cm x 33 cm x 12 cm
    Weight
    26 pounds 12 kg
  3. #13
    前級:Melody 1688 Signature
    www.ks-hifi.com
    規格
    真空管:Fullmusic 101D×2 、6SN7×4、5AR4×1
    輸出:3V (最大輸出 28V)
    頻率響應:3hz~100khz+ -1db
    輸入阻抗:250k ohms
    Channel Balance: <0.5dB (20Hz -100kHz)Channel
    輸入靈敏度:50~300mv
    S/N比::>90db T.H.D:0.02%
    總增益:20db
    尺寸:寬×高×深: 430 (W) x 185 (H) x 380 (D)
    重量: 23 Kg
    輸入:RCA輸入*4組、XLR平衡輸入*1組
    輸出:RCA高電平輸出*1組、RCA高電平輸出*1組、XLR平衡 輸*1組
  4. #14
    後級有兩套
    Melody M880Q mono x 2
    www.ks-hifi.com
    規格
    真空管:KT88EHx4、 12AU7*4
    輸出功率: 100W + 100W (8Ω) Class AB1
    頻率響應: 20Hz ~ 30KHz +/- 0.5dB
    輸入阻抗: 250 KΩ
    輸出阻抗: 4 Ω, 8Ω
    輸入靈敏度: 800mV
    S/N 比:90dB
    總詣波失真T.H.D:1%
    AC 電源:110V +/- 5%, 50Hz ~ 60Hz
    尺寸:寬×高×深: 290 (W) x 215 (H) x 530(D)
    重量: 22.5 Kg*2
    平衡輸入,RCA輸入各一組
    Ayre V-1xe power amplifier
    www.ayre.com
    Features
    All FET, zero feedback discrete balanced circuitry
    Inductor-input power supply filtering
    32 high-current output devices per channel
    Ayre Conditioner (patent pending) power line RFI filter
    Special high-speed circuit board material
    Remote control included
    Specifications
    Power Output
    200 watts continuous per channel (8 ohm load)
    400 watts continuous per channel (4 ohm load)
    Gain:26 dB
    Input Impedance:100 kohm (per phase)
    Power Consumption:40 watts in standby mode
    360 watts in operating mode, no signal
    Dimensions:18"W x 20"D x 7.75"H (45.7cm x 50.8cm x 19.7cm)
    Weight:95 pounds (43 kg)
  5. #15
    線材:NEOTECH全系列
    除了專線是用3001等級的外,其他都用上了1001旗艦
    www.neotechcable.com
    PS AUDIO Noise Harvester
    將雜訊轉換成光能 (燈泡發亮)
    www.psaudio.com
  6. #16
    好想知MELODY前級插入AYRE組合中效果如何?
  7. #17
    當天沒有實際聽到這樣的組合,主要是andychu目前比較喜歡聽Melody全套的聲音,所以這部份還要請andychu跟大家分享一下
    引用 作者: Tere5 查看文章
  8. #18
    電源專線
    一開始andychu的並沒有拉電源專線,結果音響系統老是會有雜音出現(RF射頻),後來便買了一捆NEOTECH NEP-3001拉了兩條迴路的專線給音響系統用,不僅聲音好上許多,還解決了問題,電源的處理真的是很重要!
    總電箱在後陽臺
  9. #19
    舒服與耐聽
    Sonus Faber與Melody的組合還是我第一次聽到,不過在聆聽之後,很快就可以知道andychu喜歡的是什麼樣的聲音:那就是要可以放鬆、可以聽很久的聲音。
    對於平常工作相當忙錄的他,偶爾只有周末會有比較有較長的時間可以好好聽音樂,藉由音樂來洗淨一整周工作的辛勞,若音響系統沒辦法達到這點,即使其他方面表現再好,也不能讓他喜歡。
    毫無疑問的,Sonus Faber與Melody完全達到他的要求,除了非常舒服與耐聽外,在聽人聲時,甜味更是會讓人著迷,andychu喜歡聽的音樂類型也以人聲、小品居多。
  10. #20
    其實這並不是andychu從澳洲回台後的第一套音響,當初先買的是B&W N805、Marantz PM14與Marantz 16D,後來買了Audio Space的綜合管機,又買了Audio Space的前級,現在只剩B&W N805還留著,搭配的是Melody H300B與Raysonic CD-128,等將來其他的地方完成後,當第二套的小系統來使用。
