顯示結果從 1 到 10 共計 20 條
混合查看
    預設 new Linn Akurate System
    Linn's Akurate system has been completely transformed to deliver truly exceptional performance from your cherished music collection.
    Linn Akurate is a dedicated stereo system designed with one clear purpose: to reproduce the highest quality music recordings in mind-blowing audio quality for you to enjoy in your home.
    Be first to audition our gorgeous new Akurate System and experience the beautiful sound for yourself at one of our forthcoming events.
    The new Akurate system is coming to a Linn Specialist near you very soon...more information and images will be released next week.
    http://linn.co.uk/
    小弟在等new圖片,估計有些地方象klimax
    應該會更潮流時尚的設計....
    價格貴 ??%
    預設 最新 Linn Akurate DS
    New Akurate DS
    Completely new audio board re-designed for significantly improved performance, featuring:
    -New lower jitter master clock
    -Improved DAC power supply and layout
    -New lower distortion output circuits
    -Improved internet radio support now includes metadata
    -Reduced power consumption in sleep mode
    -Digital output for more connection choices
    :o:o:o
    同時也將推出
    Akurate Kontrol (前級)
    Akurate Power Amplifier (後級)
    :P:P
    Akurate Kontrol 部份改進地方
    Possible enhancement for Akurate Kontrol (Preamp) :
    -Completely re-designed dedicated analogue stereo pre-amplifier
    -New lower distortion control circuitry for reduced noise on the audio signal to deliver higher performance
    -Galvanic isolation effectively 'disconnects' unused sources to reduce crosstalk, interference and noise
    -Balanced audio inputs and outputs
    -Front-panel headphone socket uses lower distortion Class A amplifier for improved performance
    -Front-panel AUX socket for easy connection of portable devices
    -Ethernet-enabled for easier setup over the network using Linn Konfig
    8)8)8)
    前一代的 Linn Akurate DS
    新一代 Linn Akurate DS
