第1頁,共8頁 123 ... 最後最後
顯示結果從 1 到 10 共計 75 條
主題: Amarra 2.3
    預設 Amarra 2.3
    Amarra 2.1 :: The Standard in High Resolution Playback
    Features ::
    Special $75 Gift Certificate to Reference Recordings!! Good through December 31, 2010
    Ultimate in audiophile performance
    Supports up to 192 kHz sample rates
    Automatic sample rate adjustment
    Double-precision audio processing
    RAM-based Cache for disk-free operation
    Native FLAC playback & conversion
    Choice of dither algorithms
    Amarra is $695 (USD)
    Playlist
    Independent playlist window (iTunes not required)
    Load complete playlists for gapless playback
    Use with Cache for sterling disk-free sound
    Drag & Drop from Finder or iTunes
    Sonic EQ
    Advanced multi-band EQ
    Double Precision
    Save/Open EQ Settings
    13 different filter topologies including:
    • Parametric - 1st to 4th order
    • High / Low Pass
    • High / Low Shelve
    • Band Pass / Stop
    • Notch
    • RIAA / De-RIAA
    • Emph / De-Emph, DC / No-DC
    http://www.sonicstudio.com/amarra/amarraplayer.html
    記得要依說明把之前版本先清掉..............
    先前我在比較2.1測試版的cache play與2.0聲音有非常大的不同
    有amarra的趕快聽看看吧
  5. #4
    小葉哥
    你的Amarra有開啟Auto-Dither嗎?
  6. #5
  7. #6
    因為裝完預設是開啟的,我也是後來關掉的
  8. #7
    我沒太留意耶........基本上我都會關上
    這個到底作用是啥......有點懂又不太懂
  10. #8
    有amarra的趕快聽看看吧
    如果不用Cache play,那2.1與2.0聲音有不同嗎?
  11. #9
  12. #10
    開啟後聽感上有弱音、細節減少,不過聽起來比較順.......功能是'不明的數位處理'
