第41頁,共43頁 第一第一 ... 313940414243 最後最後
顯示結果從 401 到 410 共計 424 條
  1. #401
  2. #402
  3. #403
  4. #404
  5. #405
    能大能小,勝旗這次將Burmester大系統與Tannoy + Esoteric組合的小系統輪流播放,這點子也很好,畢竟不是每個人都買得起Burmester大系統!
  7. #406
  8. #407
    貝魯奇這次展出的consonance D-linear7與D-linear8都是能支援24Bit/192kHz高解析檔案的產品,還沒開始推廣就已經要排隊等貨了,不曉得為什麼這麼搶手,等有機會可要好好來研究一下!
    D-Linear 7
    Analog Output: 2.5 RMS (RCA)
    Analog Outputs: Gold plated unbalanced RCA
    Distortion: Less than 0.002%
    SNR: More than 120 dB
    Digital Output: 0.5Vpp (RCA @ 75 Ohms), 3Vpp (AES @ 110 Ohm)
    Digital Outputs: Gold plated RCA and gold plated XLR balanced
    Digital inputs: Three USB Host, 1 LAN, 1 SCHC Card
    Dimensions: 4.33 x 8.86 x 12.60 (HxWxD in inches)
    Weight: 3.31 lbs.
    D-Linear 8
    Signal Output: 2.5V RMS (RCA, XLR)
    Digital Inputs: Coaxial S/PDIF, TosLink optical, AES/EBU and wireless USB
    Analog Outputs: Unbalanced RCA, balanced XLR and 6.5mm headphone jack
    Frequency Response: 0 Hz to 50 kHz
    SNR: More than 118dB (RCA, XLR)
    Distortion: Less than 0.001% ( RCA,XLR)
    Dimensions: 3.94 x 8.86 x 12.60 (HxWxD in inches)
    Weight: 7.7 lbs.
  9. #408
    沒想到這個小房間塞了這麼大對的Focal,原來是motou-in坐鎮難怪不用怕,調音輕鬆搞定!
  10. #409
  11. #410
