第1頁,共3頁 123 最後最後
顯示結果從 1 到 10 共計 24 條
    預設 看不懂的神奇小道具....Ground Control
    好像很神奇!!!但原理是什麼???:O:P英文太濫看不懂
    AudioPrism Ground Control Grounding Cables:^)
    http://www.ultraaudio.com/index.php?...views&Itemid=2
    http://www.6moons.com/audioreviews/g...ndcontrol.html
    這次在美國有看到老闆,就是喇叭接地,只要接上就行,有分不同等級,我想應該會有用吧
    AudioPrism的Byron Collett早在多年就發明塗在CD上的東東,後來給別人生產,近來又將其買下,其手拿得是Ground Control,用法很簡單,只要插在喇叭後就行了,有不同接頭的版本,USD 150起跳....AudioPrism還有一個可以聽電源雜訊的器材,想必不少人就知道了
    http://www.my-hiend.com/vbb/showthre...t=3066&page=24
    第一网站介紹是擴大机接地端 或其他如CD接地端及喇叭接地端都可接上
    When the terminated end of a Ground Control is connected to a speaker’s or amplifier’s negative terminal, the other end of the Ground Control just hangs there in space, connected to nothing. My understanding of electronics is that an unterminated wire acts as an antenna, and not as a way to improve grounding. But in analog audio, everything you do seems to have some effect on the sound. I’ve learned to take the explanations given for various tweaks with a grain of salt and just listen carefully, without worrying too much about whether or not the explanation makes sense. Sometimes I think that no explanation at all of how or why some of these things work would be better than an implausible one.
  5. The Following User Says Thank You to 999369 For This Useful Post:
  6. #4
    分型號是材質不同嗎???
  7. #5
    yes..............另外也要注意要用什麼喇叭端子
  9. #6
    看它的結構,感覺上就是個大天線....當工程師忙著想盡辦法除掉電路中的EMI、RFI時,卻出現這種接收RFI的天線道具,不懂...
    沙米亞咚的窩
    Eric Chu's Audio Lab
    http://98.to/ericc0922
  10. The Following 3 Users Say Thank You to ericc0922 For This Useful Post:
  11. #7
    要我花5000元買一付"天線"......no way...
  12. #8
    音響有些東西要試過才知道喔.....
    原廠不是傻子
    能聽電流雜訊這麼科學的東西也是他們家的
    http://www.audioprism.com/
  14. #9
    引用 作者: ericc0922 查看文章
    這也是我不明白的地方. 當我們花大錢在買發燒線來隔離雜訊,有的發燒器材在重點的元件上作屏壁,等等. 最後,在喇叭端或擴大機端加個天線?那前面作的工不就都白費了?
  15. #10
    音響有些東西要試過才知道喔.....
    原廠不是傻子
    能聽電流雜訊這麼科學的東西也是他們家的
    原廠當然不是傻子,但是他們的顧客?:O:O
    從我個人有限的觀察,這家公司從以前到現在的產品,他們聲稱的效果和所用的“科學解釋”,有點令人懷疑:|:|
