顯示結果從 1 到 3 共計 3 條
    預設 Linnenberg udc1 USB DAC
    Linnenberg來自德國,全世界採工廠直營方式,節省了代理商與經銷制度的開銷,直接反應價格回饋給消費者,該公司最新推出的udc1 USB DAC,定價歐元1260,上市特價歐元890。
    udc1為USB 2.0 high-speed (480Mbit/sec)介面,可支援到192 kHz/ 24bit,其電源是獨立非常充沛,非靠USB供電(5V, 500mA),DAC晶片方面為PCM1794A,與自家的cdp3E CD Player相同,類比採用動差A類,使用來自ZETEX與Analog Devices的元件,電壓整流使用來自Linear Technology的產品,超低噪音(20uV)。只有1組平衡類比輸出,無RCA。
    全部無使用opamp,並為零迴授。
    No opamps. Zero feedback. Just music.
    Features:
    - USB 2.0 compatible input
    - Jitter free asynchronous data transfer (udc1 as master)
    - Bit transparent drivers for Mac and PC operating systems
    - Precision master 3ps crystal oscillator
    - 24bit/192kHz Burr Brown digital - to - analogue converter
    - True class A, fully discrete analogue circuits with zero negative feedback
    - Ultra short signal path
    - Balanced analogue outputs with PCB-mounted gold-plated Neutrik XLR sockets
    - High current output stage
    Specifications:
    Frequency response: 1Hz - 24kHz +0.1dB -0.5dB
    Distortion and noise:<0.01% 10Hz - 20kHz at -10dB
    Output level:4V rms balanced
    Output impedance:150 Ohms
    Mains voltage:115V, 230V factory set
    Dimensions (H x W x D):55 x 165 x 224 mm
    www.linnenberg-audio.de
    看着线路感觉不错,但这种没代理商的产品发烧友没听过会买吗?
    Linnenberg也出了一台平衡耳擴 spa1
