第1頁,共3頁 123 最後最後
顯示結果從 1 到 10 共計 26 條
    預設 Boulder 3050 超級後級
    其實這消息已經很久了,去年的CES也出現了原型機,今天官方網站終於正式發表了新聞稿,不過產品的頁面尚未完成!3050單聲道後級輸出為1500W,共有5個環型變壓器、48個濾波電容與120個雙極電晶體,並採用了全新的99H增益模組,外殼本體為航太用的鋁,每台重172Kg,1對的售價約在USD 195,000。
    http://www.boulderamp.com/3050-p1.html
    NOVEMBER 23, 2011: Boulder, Colorado.
    For nearly 30 years, Boulder has been exceeding expectations in amplifier technology and performance. Today we are pleased to announce the official release of the 3050 Mono Power Amplifier, at 1,500 watts the most powerful and advanced amplifier in our history and quite possibly the finest power amplifier the audio world has ever seen. The 3050 reduces distortion to vanishing levels with a host of new engineering developments. The 3050 is the ultimate audio amplifier with an abundant reserve of power. It can produce 1,500 watts of continuous power into any load. Peak output power is a staggering 6,000 watts. 5 encapsulated toroidal transformers, 48 filter capacitors and 120 bipolar output devices make certain that voltage headroom is more than adequate, current delivery is instantaneous, damping is optimized and control of every driver in the loudspeaker is idealized. The amplifiers’ aesthetics are a dramatic step forward in audio component design. Nowhere does the casework terminate in a 90-degree angle and no assembly screws are visible. And because every piece of metalwork is carved from a single block of aluminum dedicated to each finished unit, the amplifiers’ left and right chassis do not share any common exterior parts. Even the power buttons and LED indicators are new creations. Not easy. But exceptional. A new, fully discrete, surface-mount gain stage evolved from Boulder’s own renowned 993 features prominently in the 3050, dubbed the 99H (“H” for “high voltage”), to raise the dynamic headroom of the gain stage to unprecedented levels. All 99H circuitry is sealed in a beautifully machined, textured and heatsunk housing before being potted with a proprietary mineral and epoxy resin. Every critical audio circuit board in the new 3050 is framed in an innovative, custom machined, aerospace-grade aluminum housing rather than screwed to a plate. Vibration damping material is then sandwiched between the circuit board and the frame in order to eliminate even the tiniest mechanical resonances that could have any possible effect on the clarity of the musical signal. Because of the tremendous weight of each 3050 (380 lbs./172 kg), every unit is shipped with a stable platform of alternating layers of black granite and polished stainless steel that is custom cut to the angles and dimensions of each chassis. This is no longer just an audio component, but art on a pedestal. To learn more about the Boulder 3050, click here.
    www.boulderamp.com
  5. #3
    總算要來了~~~~~
  6. The Following 2 Users Say Thank You to Musk For This Useful Post:
  7. #4
    好屌!!
    但,功率線性還是不足!!
    大功率或功率線性,我選擇功率線性為優先考量!!
  8. The Following 4 Users Say Thank You to 將軍 For This Useful Post:
  9. #5
    到時候到臺灣再來感受一下其威力了.........非常令人期待呀!
  10. #6
    Mono Power Amplifier.
    New power amplifier offers unprecedented levels of power and
    clarity and is the highest performing product in the history of the
    company.
    For Immediate Release; Boulder, Colo., 09 December, 2011: For nearly 30
    years, Boulder Amplifiers has been America’s premier manufacturer of
    high-performance audio electronics. We are very proud to announce the
    official release of the 3050 Mono Power Amplifier (MSRP US$195,000). The
    3050 is the largest and most powerful amplifier in the history of Boulder’s
    product range, delivering 50% more power than the 2050 Mono Amplifier,
    already widely acknowledged as the world’s finest audio amplifier by no
    small margin.
    Nearly 100% of circuitry and assembly of the amplifier was refined or redesigned
    during engineering of the 3050. Noteworthy improvements and features include:
    • Massive Power Output. With an abundant reserve of power, the 3050 is
    the ultimate audio amplifier. It will produce 1,500 watts of continuous
    power into any load and requires a 240VAC mains feed. Peak output
    power is a staggering 6,000 watts. 5 encapsulated and potted toroidal
    transformers, 48 filter capacitors and 120 bipolar output devices ensure
    loudspeaker is ideal. Distortion is 0.0006%, unheard of for an amplifier of
    this size.
    • Distinctive, Modern Architecture. Despite their size, the amplifiers’
    aesthetics are a dramatic step forward in audio component design. The
    exterior of a pair of 3050s is truly unique. Nowhere does the casework
    Because every piece of metalwork is carved from a single block of
    • Substantially Improved Noise Floor. Improvements in the circuit layout
    properties of electronics originally developed for the 1008 Phono
    Preamplifier led to further engineering advances in the 3050’s new circuit
    architecture. As noise is reduced, more low-level information from the
    recording is revealed and rendered more accurately.
    • New 99H Gain Stage. A new, fully discrete, surface-mount gain stage
    3050. The new gain stage, dubbed the 99H (“H” for “high voltage”),
    utilizes +/-38V rails to raise the dynamic headroom of the gain stage to
    proprietary mineral and epoxy resin. Thermal stability and increased
    reliability are thus happy by-products of dramatically improved
    performance.
    • Fully Balanced, Phase Isolated Construction. Outputs are fully-balanced
    and inputs are of instrumentation quality balanced design. Active output
    audio circuitry is separated for total isolation of mirror-imaged positive and
    negative phases. Attention to detail is, of course, well beyond
    expectations in a product of this level.
    • Framed and Damped Circuit Board Mounting. Every critical audio circuit
    board in the new 3050 is framed in a custom machined, aerospace-grade
    have any possible microphonic effect on the clarity of the musical output.
    • Custom Granite and Stainless Steel Platform. Because of the tremendous
  11. The Following 3 Users Say Thank You to Leo Yeh For This Useful Post:
  12. #7
  13. The Following 6 Users Say Thank You to Leo Yeh For This Useful Post:
  14. #8
  15. #9
    超級後級boulder 3050又有新的圖片唷!!
  16. The Following 2 Users Say Thank You to cica zhou For This Useful Post:
  17. #10
    kib 幹嘛 換代號啊??
