第4頁,共7頁 第一第一 ... 23456 ... 最後最後
顯示結果從 31 到 40 共計 64 條
  1. #31
    引用 作者: 將軍 查看文章
    好喇叭!!
    CP值高,又耐聽!!
    +1
  2. #32
    引用 作者: kib 查看文章
    忘了補充, 喇叭線是Transparent Reference
    這是什麼擴大機呀?推的動Sasha阿?
    怎麼只有接一組 input,不是有lp和網路播放機嘛?
  3. The Following User Says Thank You to E60M5 For This Useful Post:
  4. #33
    引用 作者: E60M5 查看文章
    這是什麼擴大機呀?推的動Sasha阿?
  5. The Following User Says Thank You to 小余 For This Useful Post:
  6. #34
    http://www.larosita.fr/rosita/?lang=fr&id=maverick
    Designed without any compromise we are proud to introduce our first integrated amplifier: ROSITA "Maverick".
    Maverick can be considered as a pure 2X70W analog amplifier but this power don't let imagine the instantaneous energy this Amplifier is capable.
    It's an iron hand in a velvet glove.
    Don't think to its price or its look when you will do your choice, just hear it with your favorite speakers on your favorite music without any prejudiced.
    Maverick can play any can of music on any kind of speaker. Just open your hears, your heart and let the music comes.
    Maverick is made like a timeless object, it is designed and built just with the passion of Music, with the passion of great sound and with the passion of timeless products.
    數位音樂都是採用AirPlay方式到Rosita Pi ,透過wi-fi傳輸避免實體介質產生的干擾~
    這台擴大機是Rosita最新推出的力作...Maverick....
  7. The Following 4 Users Say Thank You to 小余 For This Useful Post:
  8. #35
  9. The Following 2 Users Say Thank You to 小余 For This Useful Post:
  10. #36
    遠端設定發燒友Sancoba 家中網路
    檢查一下確定 Rosita Plugin運作順利!
  11. The Following 3 Users Say Thank You to 小余 For This Useful Post:
  12. #37
    學長:如此高人豪宅怎可稱低等下人,那吾輩不就是山頂洞人.......
  13. The Following User Says Thank You to jt716doc For This Useful Post:
  14. #38
    引用 作者: jt716doc 查看文章
    那小弟便是鐘樓怪人......
  15. The Following User Says Thank You to Svalbarrd For This Useful Post:
  16. #39
    遇到優的女生就變成低等下人了................
  17. The Following 5 Users Say Thank You to Leo Yeh For This Useful Post:
  18. #40
    遠端幫發燒友Sancoba裝mac mini 相關軟體,順便應景一下來個阿吝的寂寞不痛!
  19. The Following 3 Users Say Thank You to 小余 For This Useful Post:
