令人羨慕的進步!讚!!:P
張老師的服務真的沒話講啊!
最近為G1000換上重量級腳架,並將腳架腳錐換成BDR
M8轉換螺絲
腳架底部
四根粗大的圓柱皆填灌鋼珠六成五滿,二支腳架用掉約73kg鋼珠
鋼珠25kg裝
0.5mm鋼珠
空心鋁柱灌滿鋼珠 ---> 背景"噪音"降低,聲音凝聚但生硬
重量級腳架+BDR角錐 ---> 很穩固,高頻較滑順泛音增加,中頻聲音密度較高,低頻紮實有力
新腳架(40cm高)較舊腳架矮了5cm,墊了較高的花崗石,整體高度比原本低了約3.3cm,花了不少時間及勞力調整擺位
Audiplan訊號線 ---> 除了前述,高音較甜潤多汁醉人
PS.用來墊ASR電源及電池的vibrapod,可能使用不當壓壞了而移除
正常使用過vs壓壞的vibrapod
vibrapod使用上請留意,即使規格上的承載要高於器材重量,但器材重心並不一定位於中心,大部份一邊重一邊輕
若器材很重可考慮使用三明治墊法調整vibrapod位置使承重均等,別像我8個壓壞6個......悶:(
vibrapod壓壞烤箱烤一下就回來了一下就回來了。
作者: Fong
請問怎麼烤?是用一般的烤箱?需要能定溫?
作者: martinsun
我是用那種一般的家用烤箱烤的,原廠說明如下:
http://www.vibrapod.com/faq.htm
Q. I have put too much weight on my VIBRAPOD Isolators or Cones and they are squashed. Is there any way to fix this?
A. Yes. Place the squashed VIBRAPOD Isolators on a flat cookie sheet and bake in an oven at 175° to 200° F ( 80° to 94° C) for at least 20 minutes. Remove from the oven and place in a safe area away from children until they have cooled. You may want to wait several hours for them to return to their normal consistency before putting them back in service.
DO NOT MICROWAVE.
另外關於一邊偏重的問題:
Q. My component is much heavier on one side. How do I use VIBRAPOD Isolators and Cones?
A. Use a combination of Models 1, 2, 3, 4, and 5 VIBRAPOD Isolators placing the Models 3, 4, or 5 VIBRAPOD Isolators under the heaviest area of your component and either the Models 1, 2, or 3 VIBRAPOD Isolators under the lighter areas.
我自己是都用比原廠建議承重在大一號來用,不過那種機器重心差很多的我沒試過。這東西我用在cdp上覺得直接用不耐聽,但用原廠建議的三明治用法效果很好:
http://www.vibrapod.com/isolatorinst...brapodSandwich
作者: Fong
真的烤一下就回來了,感謝Fong:*
