第1頁,共4頁 123 ... 最後最後
顯示結果從 1 到 10 共計 36 條
    預設 Meridian Explorer USB DAC
    Meridian發表的隨身型USB DAC,重只有50g,3.5mm可同時輸出類比或數位訊號(96kHz)
    USB DAC為非同步,可支援到24Bit/192kHz,有輸入解析位元的指示燈,6層PCB設計
    本體為鋁金屬,USB供電,價格約在台幣萬元左右,
    http://www.meridian-audio.com/en/col...plorer-1000/4/
    Inputs
    USB mini type B.
    Outputs
    3.5mm combination analogue/digital jack with mini Toslink digital optical <96 kHz output and 2-ch analogue line out, fixed 2v RMS.
    3.5mm jack with variable-level headphone output, 130mW into 16Ω.
    Construction
    Extruded Aluminium shell with moulded plastic endcaps and rubber foot.
    Power
    USB, nominal 5V at <500mA.
    Indicators
    Three white LEDs show connected state and audio stream rate.
    Implementation
    USB audio class compliant 2.0 HS 480Mb/s bandwidth.
    Asynchronous: device is the clock source for high quality.
    Firmware upgrade via USB.
    Windows drivers provided, no drivers required for Macintosh OS X or Linux.
    Analogue volume control for headphone output, controlled from PC, control law modified to match connected OS.
    S/PDIF output downsamples 4x (192/176.4kHz) to 2x (96/88.2kHz).
    OS requirements
    Macintosh OS X 10.6.4 (Snow Leopard) or later
    Windows XP SP3, Windows 7 SP1 or Windows 8
    Linux kernel 2.6.37 or later and ALSA version 1.0.32 or greater
    Dimensions (approx)
    102 x 32 x 18mm (4.0 x 1.25 x 0.7in).
    Weight (approx)
    50g (1.76oz).
  2. The Following 4 Users Say Thank You to Leo Yeh For This Useful Post:
    售價挺嚇人,不曉得音質表現如何
    有, 有興趣的話歡迎跟我們功學社音響聯絡!!
  5. The Following User Says Thank You to khsaudio For This Useful Post:
  6. #4
    好小巧可愛,照片中的實體看起來也頗精緻,小型化就可以隨身攜帶,聽音樂更方便了。
  7. The Following User Says Thank You to hidoson For This Useful Post:
  8. #5
    實體非常輕巧, 非常適合隨身攜帶
  9. #6
    不知是否支持iphone(用轉接頭的話)?
  10. #7
    音場定位音樂性佳,生動。
  11. The Following 2 Users Say Thank You to nanayao For This Useful Post:
  12. #8
    有現貨
    訂了
    不便宜,可買1.6隻蜻蜓
    無中文說明書
    看是否有善心人有開箱.....使用說明.....驅動設定教學
  13. The Following 2 Users Say Thank You to j49409 For This Useful Post:
  14. #9
    這是真的, 您的確是搶到頭香!! 這的確是個化腐朽為神奇的東西, 就請您好好享用吧!!
  15. The Following User Says Thank You to khsaudio For This Useful Post:
  16. #10
    這價格不算便宜,勝在小巧簡單(體積與蜻蜓相比,還算能接受)
    音效不指望與大台機子比,好比傻瓜相機,無法與同價單眼相機比
    傻瓜相機還是有它的市場,有能力的可以搞來超值的東西
    沒辦法的就只能相信大廠產品,這錢只好讓品牌商賺了
    不過從沒用過數位流的東西,如何輸出音效設定,還要摸索
    樓上的 khsaudio 業代大哥是否能幫忙搞個指導文,嘉惠不懂英文的老人家
    此篇文章於 2013-02-27 06:58 PM 被 j49409 編輯。 原因: 重新修改內容
  17. The Following User Says Thank You to j49409 For This Useful Post:
