顯示結果從 1 到 7 共計 7 條
    預設 JCAT - sub-brand of JPLAY dedicated to hardware.
    JPLAY推出新的子品牌JCAT,將創建終極的PC音頻傳輸作為目標,極大化JPLAY的效能。
    JCAT將推出三個新產品,JCAT USB CABLE、JCAT LAN CABLE、JCAT SATA CABLE。所有產品皆可在此連結http://jplay.eu/jcat-preorder/以299EUR訂購(原價349EUR)並瀏覽更多細節,產品將在九月份第一周開始出貨。
    JCAT USB CABLE
    High-end USB cable for USB DACs and USB-S/PDIF converters.
    - standard length is 1m*
    - silver plated copper
    - multi-core conductors
    - multi-stranded
    - teflon coated
    - connectors made of solid aluminum
    JCAT LAN CABLE
    - multi-stranded
    - teflon coated
    Highly recommended for:
    - direct connection of Control PC and Audio PC in JPLAY StreamerMode
    - connecting Control PC and Audio PC to router/switch
    - connecting NAS to router/switch
    JCAT SATA CABLE
    - standard length is 40cm*
    - multi-stranded
    - teflon coated
    - connecting SSD or HDD SATA drive with operating system on it
    - connecting SSD or HDD SATA drive with music library on it
    Our extensive tests showed that using audio grade SATA cable is as important in computer audio system as using high quality USB cable for USB DAC.
    並提供其他優惠如下:
    20% off Set of Five Patricia Barber CDs
    25% off Patricia Barber's Companion DSD Album Download
    30% off Set of Four Patricia Barber CDs and a DSD Download
    官方網站 http://jplay.eu/
    此篇文章於 2013-08-27 03:41 PM 被 Ted Chen 編輯。
    NO ~~不知道跟龐大的~~線材比起來如何 ==~~
    在等龐大的新線也是給JPLAY 用的 ==
    真誠
    引用 作者: KangSir 查看文章
    Marcin(Jplay)已經把價格傳給我,待一些細節(長度、規格)確定後,應該會辦團購,有興趣的話可以留意一下
    引用 作者: KangSir 查看文章
    這就是龐大所代工的
    哈哈
    引用 作者: KangSir 查看文章
    試過了,JCAT的線是根據JPLAY所設計的,用在JPLAY最對味,用在amarra上反而是子勻較好聴,龐大還有開發新的子勻系列的線,其中也有平價的
