顯示結果從 1 到 4 共計 4 條
    預設 THIEL Audio TT1 落地喇叭
    好久沒有關於Thiel的消息,這次發表了新的系列3rd Avenue Collection,其名字源自Thiel公司所在地的主要街道,目前有兩款上市,一款是TT1落地喇叭,一款是TM3書架喇叭。TT1使用4單體多階分音線路,外型設計也相當新穎,
    ALUMINUM WOOFER 鋁低音
    Jim Thiel loved aluminum cones for their low mass and pistonic rigidity. We feel the same way, and so do the Danish craftsmen at Scan-Speak, who produced these woofers specifically optimized for the TT1 under the direction of THIEL Engineering. While one 6.5” Aluminum woofer might have been nice, we felt two would provide the gravitas befitting a speaker of this caliber.
    FIBERGLASS MIDRANGE 玻璃纖維中音
    Fiberglass cones combine low mass and high rigidity with greater damping than other materials. So we chose it as the ideal material to use while working with SEAS on a midrange cone that would define “uncolored.” This 4.25” midrange is perfectly matched with the woofers and tweeter in the TT1.
    TITANIUM DOME TWEETER 鈦高音
    We chose Titanium dome tweeters in the TT1 because the high frequency break-up mode (which typically occurs at inaudible levels) is more damped than other materials. In addition, the waveguide helps activate your listening space without blurring spatial imaging.
    SYSTEM INTEGRATION CROSSOVER
    How do you fuse three critically engineered components into one system? At THIEL Engineering, we went beyond mathematical formulae to not only reduce distortion but dial in the sensitivity. And our efforts were rewarded with the performance of the TT1. It employs a multi-order crossover that aligns multiple variables to ensure the drivers are merged for the purest sound possible. This improves the reliability of the entire system, enabling it to handle the power you use to listen - at the volume you like.
    ACOUSTICALLY NEUTRAL ENCLOSURE
    Form follows function, with graceful curved edges that minimize diffraction. Inside, each driver has its own chamber to reduce the internal standing waves. And as with so many of our design elements, we removed as much ‘noise’ from the system as possible, leaving you with the most accurate sound reproduction possible.
    LOW TURBULENCE PORT
    From the length, diameter and curve to the flared mouth, this port is optimized to project low frequency energy without adding or subtracting from the source.
    Frequency Response (Bandwidth) 39Hz to 30KHz
    Low Frequency Limit (-10dB) 27Hz
    Sensitivity 88dB (Anechoic); 91dB (In-Room)
    Nominal Impedance 8 ohms (3.7 ohms Minimum)
    Crossover Type 3-way Multi-order Crossovers
    Crossover Frequency 350Hz, 2.3KHz
    Driver Compliment 1” Titanium dome Tweeter
    4.25” Fiberglass cone Midrange (Die-cast Aluminum basket)
    2 x 6.5” Aluminum cone Woofer (Die-cast Aluminum basket)
    Dimensions 41.1” (H) x 10.2” (W) x 10.0” (D)
    104.3 cm (H) x 26.0 cam (W) x 25.4cm (D)
    Weight 58lbs (26.4Kgs) each
    http://www.thielaudio.com
    跟以前的外型差很多
    這對價格應該也不便宜吧@@
  4. The Following User Says Thank You to waokgla For This Useful Post:
  5. #3
    經營團隊是不是換人了??
  6. The Following User Says Thank You to sp007 For This Useful Post:
  7. #4
    引用 作者: sp007 查看文章
    經營團隊是不是換人了??
    除了品牌名字一樣, 應該跟以前完全兩回事了............
  8. The Following 2 Users Say Thank You to nickhsu For This Useful Post:
