提供給Wa6、Wa6se用家參考!
截至目前為止,Wooaudio官網上,現在Wa6可用的真空管轉接座有:
1. 6DE7--->6EM7
2. 6DE7--->7N7
3. 6DE7--->6SN7
而Wa6se目前可用真空管轉接座有:
1. 6DE7--->6EM7
官網評論:
The 6EM7 is the ultimate driver/power tube for the WA6-SE. It has great extension and excellent clarity on all frequency range. You will hear each note with breathing air around it. The sound is smooth and well balanced.
This tube is compatible to the WA6-SE. NOTE: Serial number begins with 0410 is not compatible unless a modification is done. You will need to use a tube adapter becaue the pin layout is different than the 6DE7/6EW7. It is a twin triode tube with high amplification factor. It produces higher output.
另外6DE7--->6SN7轉接座,官網上賣的並不適用於Wa6se。
Wa6se若要使用6SN7的話,除了等Wooaudio外,還可找美國Ebay上一位2359glenn購買。
The Following User Says Thank You to john999 For This Useful Post:
