2013-05-02, 01:05 PM
#4401
2013-05-02, 01:09 PM
#4402
用馬克那隻麥克風調完應該有85分了,如果換Mcintosh那台,基本上聽說是換個殼而已,不過................樣子比較好看,視覺應該可以幫助加個幾分。
昨天又回來了幾個秘密武器,也買了一個秘密武器,再加個幾分應該不成問題,要破90就要換沙發了。
2013-05-02, 01:12 PM
#4403
OK, Lyndorf處理完的效果真的很不錯, 但隱惡揚善也不是我的作風~~~
聲音有遺憾嗎? 真的要雞蛋裡挑骨頭, 昨天在場的人都認為, 人聲在形體以及密度的地方還有進步的空間,
怎麼說呢? 看圖也是可以說故事的!
我們來看1/12 octave平均過 (方便解讀, 但又不過度粉飾太平) 的頻率響應,
注意400~700Hz這一段, 處理完後 (紅色的線)反而更低了 (遠離基準),
平均差異在5dB左右!
或許是低頻的校正量稍大, 或者壓低拉高一起做也連帶影響中頻了吧?
不過我認為這個問題透過喇叭擺位應可以有效地解決, 將兩聲道的距離適度縮小一些應可適度補一下這個頻段!
The Following 4 Users Say Thank You to chsiang For This Useful Post:
2013-05-02, 01:17 PM
#4404
公慾疝氣事必先粒泣氣,等更精準的測量麥克風跟自己的機器到齊後,再請你來量,大家再一起討論怎麼擺位跟調整啊。
而且這台機器每次校正後的結果,聲音都略有不同,這次因為你的線的關係,沒辦法量到座位後上方近天花板的地方,下次多幾個測量點,校正應該也會更準一點。
昨天把NBS拿回來後,插上Lyngdorf,你提的部分有更好一點
作者: chsiang
怎麼說呢? 看圖也是可以說故事的!
平均差異在5dB左右!
此篇文章於 2013-05-02 01:26 PM 被 AndyChu 編輯。
2013-05-02, 02:59 PM
#4405
沙發靠頭的地方!lyngdorf唯一無法校正的地方就是皇帝位耳朵的後方!
2013-05-02, 03:04 PM
#4406
2013-05-02, 03:19 PM
#4407
原廠說明:
Due to the fact that a traditional box loudspeakerhas omnipolar dispersion in the bass region, this ‘free space’ placement has a big disadvantagenamely that you actually risk ‘destroying the impulse response. If you place the loudspeaker close to the back wall the bass reflections from the wall and thedirect sound will arrive simultaneously at the listening position – i.e. the impulse response inthe bass region can be improved considerably and RoomPerfect can easily compensate forthe uneven frequency response as a consequence of the placement. So, with RoomPerfect, itcan actually be an advantage to choose what’s normally regarded as a less ideal ‘close wall‘loudspeaker placement as this will not only improve the impulse response. Also, whencompensating for the increased efficiency, the load on both amplifier and loudspeaker isdecreased whereby less distortion and better headroom is achieved. And taking energy out ofthe system also has another advantage since pumping less energy into the room means thatroom modes are less excited. Thus you achieve a much more even power response across theroom – i.e. the differences between peaks and dips in the response are reduced dramatically.
The Following 2 Users Say Thank You to wayneker For This Useful Post:
2013-05-02, 03:25 PM
#4408
作者: AndyChu
麥拉!
不要買Mcintosh那台啦, 買DQEX Mate......那台功能好強喔, 我覺得更好玩!!
The Following 2 Users Say Thank You to chsiang For This Useful Post:
2013-05-02, 04:32 PM
#4409
作者: AndyChu
升級了,讚讚讚.....機器看起來好像不是很難使用...
2013-05-02, 04:45 PM
#4410
DQEX 那台要付錢跟他們連線做測試及校正。那台校正 speaker frequency-response and timing errors.而且每個單元都校正。這樣喇叭的個性會不會也被喬掉?而且它會bypass喇叭的被動分音器。
