TEAC推出攜帶式DAC耳擴 HA-P50
在iOS和PC系統下支援24bit/96kHz高解析檔案
內建BurrBrown PCM5102 D/A解碼晶片
可直接連接iPod或Android裝置播放音樂,也可直接連接類比輸出的音樂訊源
使用OPA1652 Op-Amp放大電路,並有高低增益可切換
可在APP商店或是TEAC網站下載免費TEAC HR(高解析)播放軟體
可匹配耳機阻抗為8~600歐姆
單邊最大功率為160mW(32歐姆)
耳機輸出端和類比輸入端為1/8吋耳機插孔
數位輸入端有USB-A和USB Micro B
電池約可連續使用八小時
重量:210g
大小:64 x 21.7 x 112 mm
MAIN FEATURES:
“Reference To-Go” Portable Headphone Amplifier
24bit/96kHz High-resolution Playback from iOS Devices
24bit/96kHz High-resolution Playback from PC (Windows/Mac)
Digital Direct Connection from iPod and Android Devices*
Optical Digital Audio Player for Digital Audio Devices
Analog Audio Input for Conventional Music Player
BurrBrown PCM5102 D/A Converter
Discrete Push-Pull Circuit Output Stage with OPA1652 Op-Amp
High/Low Gain Selector
Volume Control
High-resolution Audio Playback Software TEAC HR Audio
Player for iOS is available at Free of Charge from AppStore
Player is available at Free of Charge from TEAC Website.
Auto Power Save Mode
* Android Device with AOA2.0
General Specifications:
Headphone Output Power: 160mW + 160mW (32ohms)
Total Harmonic Distortion: 0.001% (100mW + 100mW )
Analog Audio Input: 1/8” Stereo Mini
Digital Audio Inputs: USB Type-A, USB Micro B
Headphone Output: 1/8” Stereo Mini
Compatible Headphone Impedance: 8 to 600 ohms
Battery: Lithium Battery (2100mAh)
Battely Life: Approx. 8 Hours
Dimensions (W x H x D): 64 x 21.7 x 112 mm, 2.5” x 0.85” x 4.4”
Net Weight: 210 g, 0.46 lbs.
TEAC: http://teac.jp/
台灣代理 勝旗: http://www.winkey-audio.com.tw
