第707頁,共727頁 第一第一 ... 207607657697705706707708709717 ... 最後最後
顯示結果從 7,061 到 7,070 共計 7268 條
  1. #7061
    真正的 USB 4.0 來了,介面是 PCIe 4.0 x4:
    https://www.msi.com/news/detail/Inte...rboards-142569
    https://www.msi.com/news/detail/All-...puting--142326
    There is also an all-new USB 4.0 PD100W Expansion Card that was introduced during Computex 2023 and it will be available in end of October as a bundle for MPG Z790 CARBON MAX WIFI. The USB 4.0 PD100W Expansion Card uses a PCIe 4.0 x4 interface, offering two USB 4.0 ports and two DP 1.4 ports. The USB 4.0 not only provides high-speed connectivity at up to 40Gbps but also supports a maximum of 100W of Power Delivery with compatible devices.
    微星最新的主機板就附送 PD100W:
    https://www.msi.com/Motherboard/MPG-...ARBON-MAX-WIFI
    https://storage-asset.msi.com/global...usb4-board.png
  2. The Following 3 Users Say Thank You to seeteeyou For This Useful Post:
  3. #7062
    Intel Optane DC P4800X with Memory Drive Technology Discontinued
    https://www.servethehome.com/intel-o...-discontinued/
    375GB 的 Optane DC P4800X 終於跌破¥1000 大關,當然只有少數淘寶賣家的說,介面是 U.2 才比較便宜:
    https://world.taobao.com/product/p4800.htm
    假如是 eBay 的話則比較昂貴:
    https://www.ebay.com/itm/276020719332
    外接電源的話可以考慮這一類型的產品:
    https://www.aliexpress.com/item/32755641755.html
    還有 USB 的另類選擇,只有 10Gbps:
    https://www.aliexpress.com/item/1005006049442537.html
    https://www.amazon.com/DGZOMYTEK-SFF.../dp/B0CFKK1CM7
  4. The Following 4 Users Say Thank You to seeteeyou For This Useful Post:
  5. #7063
    P4800x等同當年的900/905P,現在這價位真是很便宜了.
    保固沒問題的話非常划算.
  6. The Following User Says Thank You to Higuma For This Useful Post:
  7. #7064
    這一位網兄早於 2020 年就購入不少 P4800X 的說:
    https://audiophilestyle.com/forums/t...omment-1088683
    然後親自換上 OCXO 時鐘:
    https://audiophilestyle.com/forums/t...omment-1088689
    其他網兄則認為只有 Crystek CCHD-957 的 pSLC SSD 已經超越 Optane:
    https://audiophilestyle.com/forums/t...omment-1245543
    那是天價的 SSD:
    https://jcat.eu/product/m-2-femto-ssd/
    https://www.zzyzxphile.com/products/...tion_audio_ssd
    實際上 25MHz 的 OCXO 時鐘也不貴,但是必須具備 DIY 方面的經驗和器材,當然亦會失去保固的說:
    https://www.digikey.tw/zh/products/d...025-0M/5641634
    那一顆時鐘的位置則可以參考這些文章的圖片:
    https://bit-tech.net/reviews/tech/st...80gb-review/1/
    https://pcper.com/2018/09/intel-expa...k-look-review/
    英特爾傲騰內存白菜價!只要 28 塊錢,讓你的老爺機滿血復活
    https://post.smzdm.com/p/a8526xzn/
    數位玩物 篇八:小成本,大改善——傲騰内存盤可用性調研
    https://post.smzdm.com/p/ad2zp5kd/
    加速!加速!老舊SSD也能飛
    https://post.smzdm.com/p/ammrk5lv/
    利用SSD加速HDD 篇三:筆記本電腦也能用的加速方案
    https://post.smzdm.com/p/ar075kpw/
    讓普通電腦用上Intel傲騰加速的方法
    https://zhuanlan.zhihu.com/p/35882559
    傲騰和AMD的CPU,囍囍囍?這次不但要用你家的傲騰,還要用你家的軟件!
    https://zhuanlan.zhihu.com/p/70311232
    Administrator Guides for the Intel® Cache Acceleration Software and Open CAS Linux
    https://web.archive.org/web/20210127...-software.html
    https://www.intel.com/content/dam/su...s-open-cas.pdf
    https://www.intel.com/content/dam/su...AdminGuide.pdf
    Release Notes for Intel® Cache Acceleration Software
    https://web.archive.org/web/20170420...000006463.html
    https://www.intel.com/content/dam/su...1_RelNotes.pdf
    https://www.intel.com/content/dam/su...tes_3.1_GA.pdf
    Intelligent Cache Acceleration Software
    https://www.intel.com/content/www/us...rformance.html
    這個 CAS 仍然是免費,只是很久沒有更新罷了:
    https://registrationcenter-download....2.64_entry.exe
    由於便宜的 P4800X 只有 375GB,更換了時鐘之後該可以利用它緩衝一顆數 TB 或容量更大的硬碟,那麼相對便宜的硬碟也可以盡享 OCXO 時鐘的眷顧,哈哈。
  8. The Following 2 Users Say Thank You to seeteeyou For This Useful Post:
  9. #7065
    有一件很幹的事情要說...
    就是之前買芝奇DDR5 7800 16G*2 要16500新台幣
    現在只要7750
    氣死人了...
  10. The Following User Says Thank You to gangster.tank For This Useful Post:
  11. #7066
    我還在等D5成熟XDD.
    現在6000以上的參數看來都是硬超上去的,
    CL值蠻難看的.首參之後的數值都要大幅放鬆.
    5200之類的看來是原生顆粒,CL值就好看多了.
  12. The Following User Says Thank You to Higuma For This Useful Post:
  13. #7067
    實際上(筆電專用的)Core Ultra 將會仿效 Apple M2 的設計,把 16GB 的 LPDDR5X-7500 記憶體整合到處理器之中,情況亦有點兒類似以往的 Core i5-L16G7 和 i3-L13G4 那樣,記憶體掛點的時候就完蛋了。
    Xeon CPU Max Series 亦內置 64GB 的 HBM2e 記憶體,因此跟 Threadripper 7000 系列同樣高達 350 TDP,而前者毋須任何安裝 DIMM 記憶體也可以開機。
    且看明年的 LGA 1851 和第 15 代處理器有沒有甚麼突破吧。
    https://www.mobile01.com/topicdetail...=488&t=6598782
    VRM相數可比照引擎汽缸數,每個相出力固定的話,相數越多,總出力越大,換個方式說,同樣總出力下,相數越多,每相負擔越小
    第二個是提高等效交換頻率,每個相交換頻率乘以總相數,整體交換頻率可提高,減少供電dead-zone造成的輸出電壓ripple及drop
    但也不完全是沒有缺點,相數越多,元件越多,線路複雜度提高,佔用空間越大,成本也越高,另外當處理器於待機狀態時功耗下降,相數多反而耗電,不過目前主機板都有動態輸出相數分配,低功耗下會減少運作相數降低轉換損失
    其實主機板最重要的一環會不會是它的 VRM 部分呢?只要供電方面真夠強,例如 CPU 盡享 20 相或以上的 VRM,甚至好像微星 MEG Z790 GODLIKE 那種變態的 26 相(每一相均高達 105A,合共 2730A)供電給 CPU,基本上這方面已經毫無懸念。
    目前 Win11PE 的大小只有雙位數字,換句話說就是把 WIM 檔精簡到 100MB 以下的說,除了跑播放器之外大概是不會打擾到 CPU 和 RAM 了吧?畢竟所有「除褲放屁」的檔案也銷聲匿跡,不知道還有必要選購一些「超強」的 CPU 和 RAM 嗎?
    Apacer Creates the First Industrial-grade Wide-temperature DDR5 Memory Module Made with ICs Sourced Directly from Leading Manufacturers
    https://www.apacer.com/en/news/news-.../widetemp_ddr5
    https://www.apacer.com/zh-tw/news/ne...e_temp_ddr5_tw
    除了不可或缺的 Optane 之外,RAM 方面就全靠 Apacer 的汗馬功勞,最後選擇這種 CPU 就差不多了,反正只會用到 Remote Desktop:
    https://www.intel.com.tw/content/www...sor-names.html
    F 尾碼表示沒有內建顯示晶片的 CPU。
  14. The Following 2 Users Say Thank You to seeteeyou For This Useful Post:
  15. #7068
    要玩極端高時脈才需要超多VRM相數,一般CAT很少這樣設定,
    主流高階版8相 12相之類都夠了.反而可提供的Switching Freq,
    我還比較在意XDD.其實都還是回歸SI(訊號完整性)品質,但除了
    超頻性能外很難觀察這部份做挑選.所以推薦起來都是超頻取向的
    高階MB.
  16. The Following 3 Users Say Thank You to Higuma For This Useful Post:
  17. #7069
    audio PC掛掉了,得重新組一台電腦。想請教一下換過PC主要硬件的朋友,需要哪些步驟在新的主機上激活JPLAY?我發郵件到JPLAY的郵箱。兩天了沒收到回覆。
  18. #7070
    現在我新電腦已組裝好,也已發信給JPLAY說我換了新電腦。但是激活不成功。需要把主機板序列號發給JPLAY?
    已經激活了。需要發給另一個收件人。
    此篇文章於 2023-10-28 01:39 PM 被 ucyga 編輯。
