arcus incantare: MediaServer – technical data sheet
MediaServer
Frequency response 2 Hz - 20 kHz
Distortion factor < 0.002 %
Channel separation > 110 dB
Signal-to-noise > 110 dB
Audio inputs analogue 1 x stereo cinch
Analoge Audio-Ausgänge High definition 7.1 multichannel, 1 x stereo cinch
Audio outputs analogue SPDIF toslink, 24 Bit, 196 kHz
Video outputs HDMI 1.3, DVI-I
Weight 20 kg
Dimensions incl. feets 44 x 10 x 37 cm
Power supply 110 / 230 Volt; 50 - 60 Hz
Optional extras Extern memory up to 4 TB
Disc drive Selectet high end slot in drive
Used memory audio/video formatted memory with damped suspension
Memory size 1 TB, 4 GB RAM
Backup function Yes
Cooling Heatpipe System without fan
Networking wired Ethernet 10/100/1000 m/bits
Networking wireless By USB-stick
Encryption Folowing Rules
Other ports 6 x USB 2.0
Finishes Titan silver, black, white
Mechanical construction Resonance optimized full metal housing, shielded board,
vibration decoupled, stream optimized
Technology platform Microsoft Windows Vista Ultimate Certified for Dolby Home Theater,
Microsoft Windows Vista Premium WHQL
Processor Intel Core 2 Duo E8500, 3,16 GHz
Audio resolution 24 Bit - 196 kHz
Video resolution 1080p Full HD, 2048 x 1536 mit 75 Hz frequence (QXGA) for digital
and analog screens, HDCP Version 1.1 support
Supported media BD-RE/R (SL), BD-RE/-R (DL), BD-ROM (SL/DL), DVD Multi Read/
Write support, CD-R/-RW-ROM
Audio support MP3 (32 kBit/s - 320 kBit/s), WAV, WMA, Audio CDs
Video support MPEG-2, VOB, ASK, M1V, M2V, WMV, DAT, VOR, DVR-MS, H.264,
MP2, MOV, DV AVI, VC1, TS, TRP, TP, M2TS, RM, DivX AVI
Supportet formats TCP/IP, UPnP AV, DHCP, AutoIP
Supported data systems FAT, FAT32, NTFS
Country of production/manufacture Developed and engineered in Germany
