第35頁,共48頁 第一第一 ... 25333435363745 ... 最後最後
顯示結果從 341 到 350 共計 475 條
  1. #341
    PK Racing Round 4: Boulder 1021 vs DCS Scarlatti 準備中...
  2. #342
    引用 作者: musk 查看文章
    一年多前也滿想入手這一部的~~~:P
    Sony己附St Mic 不知麥克跟外接麥克相比效果如何[看看好玩]$2000特价1850+稅
    The PCM-D1 is equipped with a stereo pair of highly sensitive electret condenser microphones and designed with circuits that process stereo sound with virtually no extraneous noise. Features 24-bit/96kHz recording, 4GB internal Flash memory for 6-1/2 hours of CD-quality recording, removable Memory Stick Pro High-Speed storage (optional), and a built-in USB port compatible with PC/Mac operating systems. The body is made of pressed titanium that's 10 times harder than alumite-treated aluminum.
    Korg MR1000 $1500特价1200+稅
    With the pristine fidelity and ultimate flexibility of 1-bit technology, the Korg MR-1000 recorder ensures that your final audio mixes and location recordings are never obsolete.
    TASCAM DR680 $1400特价1000+稅
    TASCAM's DR-680 brings multichannel portable recording within reach of any musician for polished live, location and surround recordings.
    TASCAM MD-CD1MiniDisc/CD Combo Deck$950特价800+稅 [這台很實用]
    The TASCAM MD-CD1 MiniDisc/CD Combo Deck combines CD playback and MiniDisc recording in a single rackmount unit. Like all TASCAM fixed-installation products, the MD-CD1 is designed for years of trouble-free use.
    The MD-CD1 has a host of professional features like RS-232 control, digital I/O (an optional I/O board provides balanced) interfacing, MP3 CD playback, MiniDisc recording at 4X, a wireless IR remote, 12% pitch control for CDs, 16% pitch control for MDs. This TASCAM deck can even play back faster without changing pitch.
  3. The Following User Says Thank You to 999369 For This Useful Post:
  4. #343
    此(首)次受召.見識 站長調度風範. Musk哥慨然度量&美麗 副店長. 侯姐廬山真面. 無聊女神專業深入. chsiang明辨獨見. 99 哥隱身幕後.在下幸與..秉持報告務交原則.再補.
  5. #344
    心得報告
    dCS Scarlatti vs Weiss DAC202 + Mac Mini + Amarra
    老實說這次我的耳朵狀態不是很好,可能感冒還沒完全好,也或許是我忙著當DJ,共有5個人5首曲目參加試聽,我是最後一個,前面4首別人的曲目我在這回合聽不出有太大差異,到我自己選的綾戶智惠才感受到差異之處。Weiss DAC202表現可以說是非常的好,跟dCS Scarlatti相比時沒有明顯的落差,我的意思是說沒有那種一比就發現有明顯落差的情況出現,在音色方面,兩套訊源是相近的,這點也蠻讓我意外的,而兩套訊源最大的差異跟我預料中的也差不多,dCS的強項在於音符的明確與力道,還有尾韻較多,Weiss的強項在於較為監聽式的呈現,很容易聽出樂器或人聲的表現。
    Weiss DAC202 + Mac Mini + Amarra + dCS Scarlatti Clock
    DAC202可外接Clock,因此將dCS Scarlatti Clock接到DAC202,雖然只接Clock,很明顯的dCS的聲音已帶入了Weiss DAC202,音符的力道更為強勁,或者說是強弱分明,尾韻與形體也稍增加,音響性方面應該是有提升不少,不過我自己好像不太喜歡這樣的組合,可能是Weiss DAC202的特色被蓋過了。
    dCS Scarlatti PK Simaudio Andromeda
    Simaudio Andromeda因為擺設沒辦法上音響架,只好委屈的擺在地上,原廠的角釘沒開也沒裝上,雖然如此,表現已令人讚賞,其他的試聽者覺得很相近說聽不出有太大的差異,或許也是到第二回合累了,我自己曲目聽到的最大差異在與音色的改變與聲音的飽滿度,Simaudio Andromeda的鋼琴音色與dCS Scarlatti很明顯有不同,好像在聽兩部鋼琴一樣,不過都很真實,我不曉得那一台才是對的,若純粹要挑口味,我可能會偏向dCS Scarlatti一些些,較為華麗(主觀喜好),另外就是Simaudio Andromeda的全頻段聲音都較為飽滿,高音我沒特別注意,但中音與低音的部份,就明顯的比dCS Scarlatti飽滿許多,如綾戶智惠的歌聲喉音較為明顯具有厚度,還有在聽不滅の日本行進曲傑作集,低音的量還比dCS Scarlatti多,重點是還沒有亂的感覺,飽滿跟形體大可是不一樣的東西喔,若形體大就可能會亂。另外要補充的是,Simaudio Andromeda雖然是目前旗艦,聲音表現沒有話說,不過跟新上市,採用32Bit的750D聲音走向很不一樣,或許Simaudio已經在研發新一代的旗艦了!
  6. The Following 8 Users Say Thank You to Leo Yeh For This Useful Post:
  7. #345
    引用 作者: 葉sir 查看文章
    盡力吧..資淺先講囉.
    dcs..第一感是平穩..毫不費力傾洩出音符.形體浮凸.迫力逼真.凝聚強.聽 live有適當的收斂:|.先都不計空間特性/器材匹配而言.現場應該是 4/5票推~不反對吧.
    weiss..來勢頗洶..汎音討好.增加了動態/開闊感.中高樂器分離度突出.這點在 decca鄉間騎士(2段)優勢明顯..就是給足 dcs威脅啦.如果再穩一些些.音像退一點..故意亂序播.會被判win也是可能的..:O
    此回未測 paa6於空間.乃未上手/時間不夠.但整體試聽相對緊湊持氣.
    對"距離遠"又不熟的 hi-end系統聲底.只用短短數段曲要評~是客觀有難度.
    dcs..穩.貴氣.密.聽國樂/小品類內斂些.大編制收放間感覺樂團整齊度嚴謹些.要説是個相對成熟(美女:P)表現不為過.樂句/風處理方式要講偏向於..印象~國民樂派時期對比感覺(就是成熟度很高啦!)也可以.聽幾段後會給耳朵一個小烙印.誠如 無聊(卡卡) 網兄講的..如你給她 頂班日系訊源. dcs會歷歷在目~數(頭)給你看:O.而略觀前~前前次 pk賽下來.眾家挑戰者欲望給 dcs威脅.好像都不能(全)如願!8)
    而且.dcs還有終極武器~clock.加上後..對給予挑戰者的提升已然明確.自己一套接.風景更好看了:).
    現場有 網兄能對樂團表現間..樂器樂手的距離..力道..共鳴等等..做細微分析辨別的功力.這一點就厲害了..建請 站長徵召有錄音(室)現場經驗同好.帶著參與錄/製的軟體來比試.也很有趣吧.
    在此..不能不誇讚 weiss 202.袖珍簡單俐落外形.就給足"高檔美聲"絕大部份所需求的內容:以進行曲言.銅管/鈸/短笛..那種金屬該有的尾韻光輝.過癮得很.! punch感覺特別好.印象中 march錄音水準表現cd.要強過這片的應該是難找了.weiss唱起熱烈的音符來.像似活力少女.你可以對其他"方面"有意見..但是年輕就是本錢:*.小小火氣/成熟度.用點心整治調理一番.就會變一個大美人.. 站長必然心得深厚.
    容 後 再 表.
  8. The Following 8 Users Say Thank You to Yeh捨 For This Useful Post:
  9. #346
    1. Scarlatti
    第一曲RR的展覽會之畫聽來感覺富有衝擊力,低頻Punch強。
    第二曲進行曲管樂器的共鳴感以及形體感較好。
    第三曲略過,等會說Weiss的聽感。
    第四曲我帶來的曲目,貝多芬的合唱幻想曲。定位感,低頻的權威感,深度層次感均較佳。但是在這個曲目我卻覺得Weiss比較好聽,原因待述。
    第五首Live Jazz Record,無話可說,dCS的暫態反應完美,抑揚頓挫明顯,聽來只有一字爽!
    2. Weiss
    第一首高音較暗,音場較後退。
    第二首,明顯感覺形體感小一號,與第四首我的曲目交叉比對卻發現這個形體感才是較適當地.....
    第三首帕華洛帝的鄉間騎士(Decca)我意外覺得Weiss比較好聽,我聽來覺得歌聲被稍微拉近了一些些,也比較飽滿,比較有感情。這跟我前兩首聽後的預期心理有點落差。不過我要先說明Opera不是我常聽的音樂類型,所以也許並不完全懂得如何欣賞:)
    第四首我的曲目,雖然規模感較小,但是鋼琴的共鳴感恰到好處,不像dCS到處氾濫。聲音乾淨,人聲分離度較佳,音樂的流暢感一流。Weiss越到這個曲目的後面越好聽,也是顛覆了我前幾首的印象。
    第五首Weiss的暫態反應明顯遜於dCS。
    加了clock,把dCS的特色加入了Weiss。不過大抵上Weiss的聲底並沒有改變。第一、二、三、五首都變得更好,有點像是融入兩家之長。加上clock的Weiss在形體感的描繪感覺恰到好處,音響性也加強,是很好的組合。但是在我的第四首上面還是顯得稍微擁腫了一點點,我還是比較喜歡Weiss原本的表現。
    Weiss與dCS的PK,我個人覺得dCS的霸主地位並未動搖,反觀Weiss我認為必定要加上clock(也許可以用別家的clock來調音)才能真正威脅dCS。Weiss + clock以價格來說還是比dCS便宜許多,不過可以得到80%的實力,算是個划算的組合!
    說真的我完全被嚇一跳,除了聲底之外,我真的分不出來這兩者間的差異。對我而言dCS線條明顯,尤其是低頻。dCS聲底明快華麗,而Simaudio比較厚聲。感覺這會是個個人喜好的選擇,在音響性而言我不得不說這兩者實在差異有限。
    也許是CD紅皮書的規格就是這樣了吧?我真的被嚇了好一大跳.......
    心得報告先這樣,等我PAA6有點心得後在把今天的聽敢跟我自己平常習慣的聲音做個連結,希望能夠更客觀些!!
  10. The Following 6 Users Say Thank You to chsiang For This Useful Post:
  11. #347
    今天我決定去買小葉帶來的那一片了.........8):)
  12. #348
    好戲登場!
    24bit/96KHz現場生中繼,讓大家體驗一下各機之間的差異。
    Round 1
    第1首 Tutti                   dCS Scarlatti
                           Weiss DAC202
    第2首 不滅の日本行進曲傑作集・君が代行進曲   dCS Scarlatti
                           Weiss DAC202
    第3首 帕華洛帝.間騎士            dCS Scarlatti
                           Weiss DAC202
    第4首 貝多芬                   dCS Scarlatti
                           Weiss DAC202
    第5首 綾智惠FINAL               dCS Scarlatti
                           Weiss DAC202
    Round 2
    1Tutti                   Weiss DAC202
    2首 不滅の日本行進曲傑作集・君が代行進曲  Weiss DAC202
    第3首 帕華洛帝.間騎士            Weiss DAC202
    第4首 貝多芬                 Weiss DAC202
    第5首 綾智惠 FINAL             Weiss DAC202
    Round 3
    第1首 伶歌                    dCS Scarlatti
                            Simauduio
                            Simaudio
    第3首 MAHLER 5                   dCS Scarlatti
                            Simauduio
                            Simauduio
                            Simaudio
  13. The Following 5 Users Say Thank You to さおり For This Useful Post:
  14. #349
    (1) 辛苦了さおり,非常感謝
    (2) 24/96全上真的太佔空間了,以後挑兩首片段就好,不然空間很快就會爆掉
    (3) 錄音效果真的太好了,大家聽聽看吧,辨別力也很好
    (4) 以上檔案將只會留3天,第4天後只留其中兩首嘍...
  15. #350
