第169頁,共185頁 第一第一 ... 69119159167168169170171179 ... 最後最後
顯示結果從 1,681 到 1,690 共計 1846 條
  1. #1681
    兩者聲音的走向是完全不同
    就初步的試聽來說
    Zodiac Gold + Voltikus 給人非常大的音場包圍感,活生感非常好
    Weiss DAC202 則屬冷靜監聽的走向,聲音精準細膩
    兩台都是很好的器材,選擇會決定在用家的喜好口味
    音響展後將會有進一步的試聽...
  2. #1682
    問題 Audionet MAP usb port
    Hi,
    I wonder whether anyone has been use an usb cable to connect between a pc to audionet MAP? What's the peformace?
    Cheers,
    Bob
  3. #1683
  4. #1684
    不錯 thanks
    Much appreciated.
  5. #1685
    昨天聽到了Antelope Zodiac+10M銣原子鐘
    真的是很威阿!!!!
  6. #1686
    請問DCS P8i 可以放sacd/cd.也可以當DAC用.一機三用.二手的約5千美元.不曉得這樣的訊源投資合不合算.
  7. #1687
    不建議買P8i.........建議從新的puccini開始買
  8. #1688
    Zodiac Control Panel
    只要安裝後,就可從電腦直接控制Zodiac的功能.....蠻不錯的
    Now, you can control your Zodiac DAC directly from your desktop.
    Antelope Audio unveils a unique application in the world of USB DACs - the Zodiac Control Panel. This virtual remote control brings your DAC to your desktop and the firmware update just a click away.
    Managing firmware updates for your Zodiac has never been easier. Simply download the multi-platform application and install it on your Mac or PC. The control panel is completely compatible with OS X, Windows and Linux.
    In addition to the hassle free firmware update, you can easily control multiple options on your Zodiac without leaving the couch - select the source input, change the USB audio class, or activate a peak meter.
    For Zodiac Gold you can also adjust the volume, and change the headphone impedance and attenuation.
    The intuitive design and usability are complimented by a photorealistic interface that provides a direct likeness of your Zodiac DAC front panel.
    Download your Zodiac DAC desktop app here.
  9. The Following 3 Users Say Thank You to Leo Yeh For This Useful Post:
  10. #1689
    ASUS Xonar Essence One USB DAC
    開箱
    在ASUS推出XONAR Essence STX高階High End音效卡後,今年又推出高階High End的Xonar Essence One USB DAC,看來ASUS的老闆應該有人是發燒友才是!
    非常精美的包裝!
    隨機附上電源線、耳機3.5轉接頭、USB線 Type A→B
  11. #1690
    有曲線的外觀設計
    兩顆大旋鈕,右邊一顆是耳擴音量、左邊那顆是DAC音量,另外取樣頻率有一檔是BIT PERFECT,這就稀奇了,厲害,晚點來研究看看如何辦到的,另外還有一個Mute靜音鍵
    電源、Upsampling升頻與Input的選擇
    Xonar Essence的Logo?
    有1組RCA、1組XLR平衡輸出
    數位輸入有USB DAC、同軸與光纖,另電源有國際電壓可調
