第1頁,共14頁 12311 ... 最後最後
顯示結果從 1 到 10 共計 140 條
    預設 Olive O6HD 音樂伺服器
    O6HD是Olive目前的旗艦產品,24Bit/192kHz解碼能力,全平衡DAC與10.1"玻璃的觸控螢幕。
    ‧全平衡DAC (配對的Burr-Brown PCM1792晶片),S/N比為124 dB
    ‧極低時基的主時鐘 (小於10 picoseconds)
    ‧表現極好的升頻轉換:TI的SRC4194晶片,升頻到24Bit/384kHz
    ‧High End等級的輸出級:極快速低失真的OP放大(20V/us slew-rate),溫和的2次Bessel reconstruction濾波,非常平坦的頻率響應(+0/-0.5db, 20Hz-20kHz)與極低的失真(THD+N of less than 0.0007% (at 20Hz-22kHz))
    ‧獨立的耳機解碼DAC:PCM1792 DAC與TPA6120A2放大
    ‧高精準線性電源:類比與數位獨立,類比使用極低噪音的線性電源。此外還有獨立的AC濾波,噪音降低至80dB。
    ‧美國設計與手工打造
    ‧鋁製本體,減少操作噪音與共振。
    ‧10.1"的彩色玻璃觸控螢幕。
    ‧2TB的硬碟,可存6000張CD或20,000首高解析檔案。
    ‧專門設計的2個部份的減振角錐。
    ‧獨特無風扇的散熱系統。
    www.olive.us
    代理:小高音響
    規格
    Fully balanced differential Digital Analog Converter (DAC)
    Two TI 192khz/24-bit Burr- Brown PCM1792 running in mono mode
    Ultra-low jitter master clock (10 picoseconds after re-clocking)
    TI SRC4194 Asynchronous Sample Rate Converter (Up-sampling to 24-bit/384 kHz)
    Ultra-fast op amps (< 20V/us slew-rate)
    Analog filter: 2nd-order Bessel reconstruction filter
    State-of-the-art technology platform & high-speed processor
    Flawless encoding and decoding of lossless audio format
    Fast management and access to extensive music libraries
    Supports simultaneous streaming of high quality audio to multiple rooms
    Hard Drive
    Ultra-quiet 2TB AV hard drive
    Holds almost 20,000 HD tracks or 6,000 CDs in original quality
    Cushioned in 8 layers of noise cancelling padding
    CDRW
    High fidelity TEAC CDRW mechanism
    Import: Audio CDs
    Burn: Audio CDs, MP3 CDs, Data CDs
    High-end Headphone Output Powered by...
    Dedicated TI 192khz/24-bit Burr- Brown PCM1792
    TI's top-of the line TPA6120A2 High Performance Audio Amplifier (current-feedback architecture)
    Audio Connectors
    Analog Output:
    - 1x XLR (balanced), made by Neutrik
    - 1x RCA, (24k gold-plated)
    - 1x Headphone, stereo, 6.4 mm
    Digital Output:
    - 1x AES/EBU (balanced), made by Neutrik
    - 1x S/P DIF optical Toslink,
    - 1x S/P DIF coaxial cinch, 24k gold-plated
    Supported Audio Formats
    Bit rate: 16-bit, 20-bit, 24-bit
    Sampling Frequency: 10kHz up to200kHz
    WAV, FLAC, MP3 (128 and 320 kbit/s),AAC (128 kbit/s)
    Networking
    Wireless, 802.11n (54 Mbit/s),
    Encryption:WEP, WPA, WPA2, 64- and 128-bit
    1x Wired Gigabit Ethernet
    Other Ports
    1 x HDMI (480p, 60Hz)
    1 x USB 1.1/2.0
    Infrared Receiver Input
    Color touch-screen
    10.1'' wide-aspect ratio
    High-resolution (800 x 480 pixels)
    Glass-on-Glass touch-screen technology
    High-precision linear power supply
    Separate supplies for analog and digital components
    High-performance AC line filter
    (ultra-high noise attenuation at close to 80db)
    Custom-built toroidal transformer
    Large reservoir capacitors
    Ultra-low noise linear regulators
    (two stages of regulation, dedicated linear regulator for the clock generator)
    Passive cooling concept no fan
    Design
    Anodized fine-grade aluminum shell
    Passive cooling without noisy fan
    Ultra-quiet operations
    Measurements
    Width 17.125"
    Height 4.5" (at highest point)
    Depth 14"
    Weight 16.5 lb
    Color
    Silver or Black
    Box also includes
    User manual, Remote control with battery
    w/ battery, WiFi-antenna, Power cord.
    Audio Performance
    Measure Line output Headphone output Comment
    THD + N 0.0007% 0.0007% 20Hz-22kHz
    Signal/Noise Ratio 124dB 116dB 20Hz-22kHz
    Dynamic range 121dB 113dB 24bits/96kHz
    Linearity >110dB >110dB
    Channel separation >120dB >110dB
    Ouput level 2V RMS 4V RMS Unbalanced
    4V RMS -
    Residual output noise 1.8uV RMS 6.0uV RMS Unbalanced,
    A-weighted
    2.5uV RMS - Balanced,
    A-weighted
    Frequency response +0 / -0.5dB +0 / -0.5dB 20Hz-20kHz
    太銷魂了...8)8)8)
    享受音樂中...:)
    這台挺誘人的,外型也不錯,又是一個數位訊源的好選擇,
    不知道什麼時候會有相關的試聽心得分享:o
    O6HD與O4HD的比較
    http://www.olive.us/products/music_servers/olive6hd/compare.html
    O6HD多了
    (1) 平衡設計,兩顆DAC晶片與1組類比平衡輸出
    (2) 電源分離更強化
    (3) 10.1"大型玻璃彩色觸控螢幕
    (4) 獨立的耳機DAC與放大
    (5) 數位輸出為AES/EBU
    O6HD與O4HD的比較
    O6HD多了
    (2) 電源分離更強化
    (3) 10.1"大型玻璃彩色觸控螢幕
    (4) 獨立的耳機DAC與放大
    (5) 數位輸出為AES/EBU
    不過O6也少了Digital in,看來不能當純DAC,定位是就是作為
    訊源的用途了
    超酷的
    到貨了嗎??
    美國剛出貨
    遇到美國新年與臺灣新年
    到貨時間有的拼
    價格最關心,現在有透露?
    USD 5,000 (未稅)
    臺灣可能要訂20多萬........
