KEF T205榮獲EISA大獎: 最佳影音產品2011 - 2012
KEF T205榮獲EISA大獎
最佳影音產品2011 - 2012
T205是KEF的5.1聲道系統,其只有3.7cm的厚度使其在眾多對手中脫穎而出,獲得EISA(歐洲影音協會) 最佳影音產品2011 - 2012。不像傳統單體錐盆硬且淺的設計,其使用了專利的雙層單體設計,無論是掛在牆上、或是放在KEF腳架上,衛星喇叭與重低音都能輕鬆的整合在一起,擁有一致完整的聲音感受,超低音為D類250瓦,特殊的設計使其貼牆擺也沒問題。
http://www.kef.com/tw/surroundsound/t-series/t205
EUROPEAN 5.1 LOUDSPEAKER SYSTEM OF THE YEAR 2011-2012
KEF T205
In the race to produce the slimmest home theatre loudspeakers, KEF is on the winner’s podium with its black T-series satellites that are a mere 3.7cm deep. These are not lo-fi panel speakers but employ proprietary twin-layered drivers, rather like a conventional cone made very rigid and shallow. Designed to sound impressive whether hung on the wall or mounted on KEF’s floorstands, the satellites and partnering subwoofer are smoothly integrated into a cohesive system with little adjustment required on the part of the user. The subwoofer employs a 250W Class D amplifier, its elegant profile also optimized for use close to a rear or side wall. KEF’s T205 speaker system is a skinny latte that’s big on flavour.
(以上內容節錄自EISA)
