顯示結果從 1 到 10 共計 11 條
主題: Hegel HD10 DAC
    預設 Hegel HD10 DAC
    來自挪威的Hegel發表了新的DAC,HD10,約在USD 1,200左右,數位部份除了2組同軸、1組光纖輸入外,其最特別的就是有1組可支援到24 bit/192 kHz,類比則有1組RCA,1組全平衡輸出。
    HD10 High-End Digital to Analogue Converter (DAC)
    Digital inputs: 2*coaxial, 1*optical and 1*USB soundcard
    Line outputs: 1 pair of XLR balanced, 1 pair of RCA unbalanced
    Frequency response: 0 Hz to 50 KHz
    Phase response: Linear Phase Analogue filter
    Noise floor: Minus 140 dB
    Distortion: Less than 0,001 %
    Power supply: Built-in torodial transformer, 30.000 uF capacitors
    Dimensions/weight: 6cm * 21cm * 26 cm (H*W*D), 2,8 Kg
    www.hegel.com
    Hegel USB Technology
    The USB connector found on Hegel amplifiers and digital to analogue converters opens a whole new world for music and movie lovers. This functionality allows you to easily connect your Hegel product to any computer with a reasonably new Windows or Mac Os operating system installed. The most common Linux systems will also work.
    What is the Hegel USB input?
    The Hegel USB technology is actually a computer sound card, or audio controller if you like. With the Hegel product connected, all sounds usually played through your computer will now be played through the Hegel.
    What can it play?
    The Hegel will, when connected take over all sounds. This means you can play music, video, computer games, internet radio or hear the occasional "DING" when you press and hold the Windows ANY-key for too long. Everything with superb Hegel sound
    What is the benefit?
    The major benefit is noise reduction. Inside a computer you have all kinds of noise generating equipment. And especially the very low-gain analogue signal is very exposed to noise inside a computer. So just moving the sound card out of the computer gives a real benefit.
    So what is so special about the Hegel sound card?
    Well, it is not like computer manufacturers have not tried to do their best for years. And many of our competitors have tried doing great separate sound cards too, these last couple of years. The special thing with Hegel is that we do real life experiments. For example we found that the DAC-chip it self only had limited importance. The implementation of it, however, had a major impact on the sound. Compared to any other external USB sound card you will find the Hegel more quiet, more dynamic and with less distortion.
    感覺真是便宜大碗耶~~~~~~~~~~
    這家聲音真的有一套,之前試過CD機
    不過他說USB DAC 部份可到24Bit/192kHz,我就不是很瞭解了
    這家聲音真的有一套,之前試過CD機
    內建電腦音效卡的原因嗎?
    The HD10 has a built-in computer soundcard of very high quality.
    http://www.hegel.com/hd10.htm
    不瞭,因為他是用電腦裡的軟體撥放,且透過USB |(|-
    是USB輸入可到24Bit/192kHz?
    感覺小葉兄的文章還沒寫完.... (think)
    對的,這是我想不通的地方
    USB 1.1 可到24/96非同步
    USB 2.0 可到24/192 => 不過軟體晶片出來了?:O
    引用 作者: Musica 查看文章
    這邊有提到丹麥的價格~~貴很多
    Hegel HD10 High End DAC
    from usb .,it seems to be 16bit 48k
    cox is the best
    have u used this hd10 ? Mr.Y
    and could u make a judgment between hd10 and da11?
